just get the diff from the up spec mx83 its already lsd
Having just inheritited my mother in law's stock MX83 I was wondering if factory JZX90 suspension will bolt in/make much difference?
Anyone happen to have done it?
Also for changing to LSD will any model hilux dif do, 4x4 vs 4x2?
apologies if these are stupid questions, i have tried searching.
cheers Ross
past; Yamaha RD250LC, Kawasaki GPZ500s,
Toyota 1gge RA40
present; MX83
1989 white supra 7mgte manual
http://www.toymods.org.au/forums/for...pra-turbo.html
Hilux lsd will not fit
Jealousy is a curse
get a "grande" model factory diff, it is LSD.
MA70 supra LSD will fit also...generally a wider selection of ratios too...
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Selection of ratios is no wider, because you have to use the Cressida diff case, which means you have to pull the diff apart anyway, therefore can use whatever gears you like in there. Also, just getting a Grande LSD as a unit and sticking it in there is a complete waste of time if you don't pull it apart and shim it up first!Originally Posted by MR 1JZ
