Results 1 to 15 of 28
Thread: Altezza diff question
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    Default Altezza diff question
    HI all
    Im going to get my next diff from NZ can some one help me with diff ratios,Also the best ratio to suit my car 1g with a W58 in a ta23. I think the lower the better as its only used for blasting the crap out of it
    Most common modles seem to be AS200,AS200z,RS200 and the Altrezza Gita wagon
    I have done a bit of looking but can't find comprensive (spelling) list.
    Default Re: Altezza diff question
    All the Altezza's run a 4.1:1 diff, except for the 4-speed automatic gearbox one which runs a 4.3:1.
    www.billzilla.org
    Toymods founding member #3
    ASL? Backyard Mechanic thegreatestben's Avatar
    Feb 2007
    Here's a TRD item on trademe NZ $750 buy now
    http://www.trademe.co.nz/Trade-Me-Mo...-121224203.htm
    they have an a-series diff afaik.... could always swap in a JZA80 a-seriescrown wheel to get a nice, low, 3.2 ratio.
    Feb 2007
    Altezza diffs are same as F code
    there are some cheap "IS200" ratios on yahoo atm.. 4.3 and 4.5?
    check these part numbers
    4.3
    http://page8.auctions.yahoo.co.jp/jp/auction/h54636221
    4.5
    http://page2.auctions.yahoo.co.jp/jp/auction/b81938671
    Quote Originally Posted by thegreatestben
    They're an a-series. As is the late model JZA80.
    Feb 2007
    http://trdparts.jp/english/parts_lsd_mechanical.html
    Sure, but they are the same as F code.
    Says so right there. Also a mate is using an altezza cusco lsd in a F live axle.
    right, sorry misunderstood you (or, more accurately, my alcohol-addled brain couldn't quite pick up on it)
    incidentally, that site lists every diff as f-code... including the b-series and g-series from the mk3 and mkiv supras
    Feb 2007
    ah well then they are wrong except for the altezza diff,
    But yeah I want that trd unit for my gx81.
    Can't afford though :'(
    User Conversion King
    NWA
    part numbers are the same though. IS200 and RS200 = MA61=MZ12=41301-RA010
    hello
    Feb 2007
    yup yup yup, I was just saying that the the listings being all F is wrong, i'm sure that lots of them are the same.
    I would've thought heaps of guys on here would know about altezza diffs being F compatible?
    NWA
    yeh already knew.
    i see they are 10 digit part numbers. toyota probably has them on their system? ill test it out next time im in there
    hello
    Quote Originally Posted by case
    Nah you want a nice tall ratio for that combo, otherwise 1st gear will be nearly pointless. Turbo engines love tall gearing, you want to load up the engine so the turbos can build boost. I'd be aiming for a ~3.5:1 ratio.
  1. Corona RT142 diff problem any help would be appreciated!
    Last Post: 29-04-2007, 05:44 PM
  2. suspension question
    Last Post: 26-04-2007, 04:21 PM
  3. IS300 diff question
    By blueck in forum Tech and Conversions
    Last Post: 14-10-2006, 11:53 AM
  4. diff differences question :is300/is200/altezza
    By S.W.A.M.I. in forum Tech and Conversions
    Last Post: 24-09-2006, 11:03 PM
  5. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 19-04-2006, 11:25 PM
