Results 1 to 12 of 12
Thread: What would cause ECL not to work?
    ASL? Backyard Mechanic thegreatestben's Avatar
    Feb 2007
    Default What would cause ECL not to work?
    Hey guys this ones been pestering me for a while now.
    I'm trying to get my engine check light to work, but it doesn't want to work.
    After alot of fucking about i've narrowed the problem down to the ECU not triggering the W pin. The ECL circuit is fine; ie. connecting the wire to ground causes the light to come on.
    So does anyone know why the W wouldn't be responding at all?
    The guy who did the wiring to get the car running didn't do a particularly flash job.
    Details are:
    1g-gte Gen 3
    Factory Manual ECU
    Basically stock
    In a GX81 chaser
    Cheers also hope I've posted in the correct place
    Feb 2007
    Default Re: What would cause ECL not to work?
    anyone? 10 char
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    What methods are you using to try and trigger the check engine light to come on?
    Are you using the correct diagnostic process?
    Have you tried unplugging sensors on the motor to bring up faults?
    Is the globe wired to the correct circuit/pinout on the ecu?
    Maybe the ecu has an internal fault like a damaged processor or a leaking capacitor but highly unlikely as you would have way more problems if you did. More than likely a wiring problem.
    Feb 2007
    ECL doesnt work at all,
    tried bridging the t and e1 plugs that seems to work but doesnt cause the light to come on.
    The circuit is definatly hooked up right, Have checked for faulty caps, ECU appears to be in good nick.
    Even if there were no faults the light would throw out a all clear signal wouldnt it?
    I certainly hope my ECU isn't fried
    2JZ Nut Grease Monkey 98SZR's Avatar
    Jan 2007
    Well if you think you've narrowed it down to that W pin then test that wire from the ecu to the warning light, could be just a buggered wire.
    Feb 2007
    As I said, circuit works fine just getting no signal from W.
    If I take wire off've ECU and ground it the light come on.
    double checked that the light circuit is wired to the correct pinout on the ecu? traced from the description printed on the ecu's pcb?
    The jdm cluster might have used an led as the check engine light and you may be using a normal globe which might have drawn too much current through the output of the ecu whihch usually = no no. Im not too familiar with the wiring setups for both cars but that might be one scenario.
    Feb 2007
    you might be onto something with the original ECL being an LED.
    Too bad I never got a good look at the car the engine came out of.
    Was a GA70 supra.
    Oh and yep checked directly off've the pcb
    have you got wiring diagrams for the GA70 and your car?
    They will show what sort of globes are used
    Feb 2007
    My car is a standard globe, the supra could've had either or.
    I enquired about some GA70 diagrams but never got a reply.
    according to my gen3 1g diagram i have they used a normal globe for the check engine light
    Feb 2007
    well then I guess its not then
