Should be the same housing although the axles are different between the open and lsd
Hi all
Yet another mx83 diff question.
Does the LSD and open diff use the same housing?
Is it just the internals that are different?
Can LSD internals be swapped into an open housing??
I know this is really the same question put in three different ways.
Andrew.
Jealousy is a curse
housings are the same, I had the lsd and open diff next to each other, and there was no difference i could spot.
As for the axle stubs, i'm not sure what the go is there.... important part is the pumpkin bolted straight in
Thanks.Originally Posted by Jin~Jah
Somebody please give Jin Jah pos rep. It wont let me do it for some reason
Done and doneOriginally Posted by amichie
I put an LSD pumpkin in mine no worries...
woah rep boost
apparanlty i can now have a crapload more PM's too
Thanks amichie and unclewal!
planning on putting a grande lsd into my car
will the lsd diff and housing bolt straight in or are the half shafts different?
Bolts right in.
Norbie!
www.norbie.net
I have a JZA80 Supra Torsen bolted into mine with the stub axles. The stub axles are slightly longer and have clips that retain in the centre. Same bearings, just used old crown wheel. Been running it for nearly 2 years now
That is amazing considering the JZA80 lsd is an A series and the MX83 is a G seriesOriginally Posted by MX83GT
I used JZA70 torsen lsd and axles in mine.
Jealousy is a curse
I should clarify, I was told it was from a JZA80, but to make sure it would suit me, I made him measure the bearing seat diameter, centre width, crown wheel mounting hole spacing and outside diameter where the crown wheel bolted on. The measurements all matched the MX83 diff centre, so I bought it. He may not have actually known what it came from (ebay)
May have been JZX90/100. I'm using a JZA70 4.3 R&P in my car no problems.
053Style
well i have bolted in a grande lsd.
just wondering if all the grandes came out with the same ratio? 3.9?
the diff it replaced was a G292. i wanna work out if/how much my speedo will change
G292Originally Posted by ae95
Crownwheel: 8 inches
Ratio: 4.100:1
Pinions: 2
LSD Type: open (non LSD)
Courtesy of Norbie
http://www.norbie.net/ToyotaAxle/
Rep him, and use that DB for great justice.
