Results 1 to 9 of 9
Thread: 1.5 j who,s done it whats involved
    Junior Member Grease Monkey toyoda's Avatar
    Talking 1.5 j who,s done it whats involved
    i have been told its quite a basic bolt up job but surely it cant be that simple or everyone would do it
    is there any upsides/downsides to this engine mod???
    anyone have a 2j bottom end laying about??? lol
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Default Re: 1.5 j who,s done it whats involved
    It should all bolt up, simple really, get one of them XS Power manifolds (actually quite good stuff) & go big single for mucho powers
    Sliding his D1 Soarer around the UK
    i think there is issues with the timing belt and with turbo drains
    The boobs are back
    sir Grease Monkey
    tasmania
    i,ve got a complete low k 2jzge for $600 landed at the depot in melb. get a set of turbo pistons and your away. cheers bigwad
    Western Aus
    what about drains for the turbos?
    2JZGE is a bit more stuffing around then just pistons...
    sir Grease Monkey
    tasmania
    the blank in the sump casting is already there just has to have the drain hole drilled and the two small hiles drilled and tapped, same with the oil feed line for the turbo .drill and tap the block out to 1/4 bspt ,the casting boss is already there. there is no oil squirters for the pistons in the ge but the yanks rekon that they lose you hp and oil pressure anyway.the rest is preety much the same. looks like no one wants that ge of mine so i,ll keep an eye out for a set of pistons and wack a 1.5 together for a spare . cheers bigwad
    Western Aus
    toyoda, you just happened to miss a thread on this exact subject not far at all from yours that answers all of your questions.
    http://toymods.net/forums/showthread.php?t=21732
    Forum Sponsor Conversion King
    Dec 2006
    logic would say use your orig sump and put longer hoses in.
    but then again if your worried about drains you probly dont have the smarts to do the job so why bother, just get a 2jzgte complete
    Junior Member 1st year Apprentice onboost's Avatar
    Aug 2006
    victoria
    you would have to get full custom pistons since standard compression 2jzgte pistons would give you higher than 8.5 comp. Oil drains are incorporated into the sump last time i checked so you would only have to wory about oil feed which would be a simple drill and tap job or finding a fitting that already exists.
  1. Whats involved in building Race engine
    By SYC02T in forum Tech and Conversions
    Last Post: 23-06-2007, 10:35 AM
  2. What Is Involved in Going Turbo Blacktop?
    By Trekka273 in forum Tech and Conversions
    Last Post: 25-03-2007, 11:21 PM
  3. Switchable torque converter lockup. What's involved?
    By whatthe? in forum Tech and Conversions
    Last Post: 02-03-2007, 12:06 PM
  4. 2JZGE costs involved?
    By orestes in forum Tech and Conversions
    Last Post: 01-03-2006, 11:49 AM
