Results 1 to 15 of 18
Thread: TA22 with OK Monitor - Wiring Diagram Wanted
    Junior Member Domestic Engineer 71TA22's Avatar
    Carterton
    Default TA22 with OK Monitor - Wiring Diagram Wanted
    Gentlemen and ladies,
    Anyone out there got a wiring diagram for a longnose TA22 equiped with an OK monitor.
    If its available on .jpeg or .gif or .pdf file even better.
    Hope you can help.
    Mike
    71 TA22
    My Car
    Default Re: TA22 with OK Monitor - Wiring Diagram Wanted
    How close would it be to the Gen 2 RA28 OK monitor?
    River may have one I wouls assume the RA25 is similar.
    Simon
    Beige.... The new Black!!!
    Junior Member Domestic Engineer TA22 GT's Avatar
    I mgiht have one somewhere if its the same monitor as in my TA22.. Is it the 6 warning light version with the map light?
    Simon
    Quote Originally Posted by TA22 GT
    Simon
    If it is not the one 71TA22 is after I'd still be interested if you could find this as I have to work out how to wire up mine which is exactly like yours
    Mark
    Carterton
    Simon,
    Yes it is the same monitor as you have.
    I have a TA27/RA25 diagram but it only gives half the info I need.
    Mike
    71 TA22
    My Car
    OK, I'll look through my info. I assume you both have the OK Monitor computer?
    Simon
    Carterton
    I do. Cant answer for Mark.
    Mike
    71 TA22
    My Car
    No I don't have the ok monitor computer as yet (forgot to bid on it on yahoo Japan) but I reckon that I can sort something out by using other sensors/relays etc if I have to.
    I am interested to see how the factory wiring is done so I can adapt it to my needs so any diagrams would be much appreciated
    OK, I found the diagram. I'll load it up tonight. Its in Japanese...
    Like all other Toyota diagrams, it shows the wiring but not what goes on inside the computer. The problem you will have using relays etc is that the system is usually open and when a sensor fails it earths. It also runs a test when the ignition is on, during this test all lights illuminate to check the globes are good, once the car is started the lights go out. When theres a fault the relevant light will continously flash.
    Also the rear brake globes aren't 21W, instead they are 23W and you need these for the computer to read teh correct current.
    I remember the hassle I went to to sort the wiring out on my monitor. Funny that since its been functional I haven't had any faults....
    Simon
    Carterton
    Simon,
    I look forwrd to seeing your copy wiring diagram. Should be ok with the globes etc as every thing electrical on my 73 will be JDM.
    I have taken the 75 GT wiring harness out of the 71 so I pretty much have all the basics. First I have to work out all the changes I had to make to this harness (a lot) to get it to run the 71. Then its a case of splicing in the monitor and computer.
    Mike
    71 TA22
    My Car
    Here it is Mike.
    Good luck
    Simon
    Carterton
    Simon,
    Thanks for that. I guess I will have some fun over the next few days sorting it all out.
    Mike
    71 TA22
    My Car
    Yeah I had the same problem a couple of years ago. Its not ideal that diagram is enough to figure it out, you just need to take your time.
    From memory most of the wire colours from each sensor match the colours at the computer, of course the earth colours etc are standard white/black etc.
    Simon
    one darn good lookin' Grease Monkey psi_guy's Avatar
    Jan 2007
    check your PM stidnam
    Carterton
    For those interested the OK Monitor "computer" and Lamp Failure units:
    And to prove the complexity of 70's electronics. Probably what a chip the size of a full stop would do these days.
    I think I have worked out most of the wiring.
    Simon, for the Lamp failure relay on your diagram is the stop light circuit the upper or lower section? One of the circuits also has a feed going direct to the computer. The feed wire in the computer is GW which following usual Toyota convention would be from the stop light circuit.
    Mike
    71 TA22
    My Car
