Results 1 to 10 of 10
Thread: different brake upgrade??
    Default different brake upgrade??
    Just wondering if anyone has thought about using subaru wrx 4 spot calipers.These are the same as hilux but most wont need rebuilding yet for quite a while.Or if u want something bigger you could always go for the set up i have just put on my wrx
    they are awesome 335mm rotors and 4 spot monobloc calipers.Very serious brakes but kits can be built to suit supras etc.if interested let me know
    Nev
    Default Re: different brake upgrade??
    And I can get this on my AW11 how?
    Classic Not Plastic Domestic Engineer ace's Avatar
    what do you mean by the same as hilux?
    the 90mm bolt hole spacing?
    ace
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Quote Originally Posted by ace
    ace
    I doubt they are the same.
    Yes, they use the same pads, but the rotors are bigger so the mounting bolt placement will probably be different.
    Would be nice if they were the same though
    They are both a sumitomo caliper so i assume they will bolt up the same but i have not checked yet just a thought as i now have a spare set of wrx calipers here.
    Mullet if you are serious about a set of those brakes i can get them made to suit your application
    That's an interesting development...how much would I be looking at for a front set?
    Edit: How much if I order 3 sets....
    RM.
    New Zealand
    You can usually fit pretty much anything if you are willing to use a 2 piece rotor and make a caliper bracket, the big obstacle is cost. thats why everyone looks to the bolt on, grab bits from wreckers options.
    Callum
    Mullet pm me with some details of the vehicle you want them for and i will find out for you
    So any chance of double checking the caliper mount spacing then?
    These calipers are radial mount meaning they bolt up from on top of the caliper not the rear side as most conventional calipers therefore you can adapt to what ever car you like.The only limiting factor is the brakes i showed earlier require a min. 17" wheel.But in saying that you woll be able to out brake most cars on the road this side of $100k or more.
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. GX71/MX73 brake upgrade, the easy way...
    By Soarer21 in forum Tech and Conversions
    Last Post: 18-12-2005, 11:15 PM
  4. brake booster upgrade for 86
    By PDS86 in forum Tech and Conversions
    Last Post: 30-11-2005, 09:51 PM
