I suppose at one level that's a slight disappointment but you got yourself a hell rare bit of kit.
Is there room to offset grind the HKS crank?
Well, for all of those who didn't see Johns thread from Import Bits, saying he had found himself a 2.4 litre HKS stroker, yesterday with a large handful of money, and rather sore knees from begging him to sell it to me, the vulnerable HKS stroked 1G was mine As a complete engine head to sump, it took me all of 2 hours to have it stripped down to every last nut and bolt on my workshop floor, and 90% of it chucked in the bin.
At first measure I must have stuffed up the stroke, which I thought was 92mm, but didn't sound right, so after taking the head off we did some proper measuring and came up with 81mm. SO the HKS stroker is a 81mm stroke, and this engine has a 77mm bore, giving you a capacity of..... 2263cc. Honestly, its hardly worth it in my book, with an offset ground turbo crank and 77mm piston you can get the engine out to 2140cc, but I guess every bit counts. Some may argue that the HKS gasket comes in 79mm bore, and with a stroke of 81mm, a 78mm bore gives you 2320cc, and a 79mm bore gives you 2380cc, but having now sonic tested 3 blocks to see how thick we could get one to bore out that far, I can tell you now, if you went to 79mm, most blocks would have under 1mm of wall thickness left, and its always on the thrust face too, I wouldn't want to be pushing much more than 350rwhp through one for fear of splitting bores.
I presume the HKS engines must have been assembled by HKS themselves, the crank was numbered 279, and the bottom of the pistons were marked 116-1, 116-2, 116-3 etc etc, the rods have been massively polished and looks to be in the hope of lightening, even all around the sides of the rods and big ends etc. It is howevere still fitted with standard rod bolts, head bolts and main bolts, as well as oil pump etc. The Cylinder head has a very very nice port job, and to a very nice surprise today it has HKS cast camshafts, and amazingly, HKS written on the valves!!!! SO I presume this engine has everything they did for the engine, we just have to test valve springs.
Everything inside was absolutely mint. This thing looked so clean, its either done very very minimal K's, or been very well looked after, very different to 90% of the import engines you see. I'm going to clean up and check the head/valve seats, give it a skim and sell it complete, as its little use to me, and the pistons will prob go in the bin, they have seen some det or lean conditions and number 1 and 2 are severely marked on the top corner, they may be ok, but I need to get them cleaned up, the rods will go in something at some stage, and the crank, well, that I'll keep for an engine down the track, I can't use it now as I need new rods and pistons made to use for myself.
Anyway, thats my day, hows everyone elses
6BOOST
PS, No pics, and not for about a week, I'm like a kid in a candy store, it was apart by 6pm and at the engine shop by 8am to get crack tested and measured so I can order pistons and rods. I'll take pics of everything when they come back and teh head is cleaned up and reco'd.
the HKS crank less likely to crack than the stockers? that in itself would be a good thing
Bad luck hey, I was interested to see what eventuated from this engine from John's thread, and after seeing the impressive article in Zoom on your car, can imagine what a killer engine you could have made with the 2.4 bits.
And I know someone who may be interested in that head, have let him know about it so you may hear from him....
Good luck with it all the same...
Toyota Car Club (Qld)
atleats its full of goodies!
couls be interested in the cams if you wanna ofload them
If I sell the head it will be complete, and mostly because of what its worth all together, I'd really like to know whether HKS assemble them themselves, as the port work is very very nice, I've never even heard of HKS 1G valves, but it would be nice as a bolt on package, and it will be brand spankers as well.
As for the rest of the engine, I guess its a bit of both, you always hope it will be everything you ever dreamed of, 2.26 seems a long way from 2.4, 2.4 would spool my new turbo faster than my old turbo, I'm not sure how the 2.26 will go. I'm contemplating just how far I want to stretch the bore, the HKS pistons are junk, so I'll have to get new CP's made, I don't ever want the hassle of splitting a block, and 40psi is a lot for anything to take, my engine is grout filled, though I just don't know if it will take a 78mm piston relaibly.
The crank can't be offset ground, its actually mint, and already has the 42mm journal so I can get bearings off the shelf, and its also standard size, so it has some use in it yet. I definately don't want to put it in yet, I'd like to get the engine sorted and staying alive with ni issues at big power levels before I go sticking a crank as rare as this in it, and potentially have a failure and kill it, I think i'd cry
The 2 other factors in the stroke, is that 1, the rod ratio is already up to shit, with a stock length rod, it is 1.48:1, and I have 3mm longer rods in my engine, if we move the pin even further(into the oil ring land) I can still get a 3mm longer rod in there for a 1.51:1 rod ratio. Its still crap, and I guess you could say why bother, but every bit helps, and the shorter the pin height, the lighter the piston/shorter skirt. The second factor is block clearance. Even with stock rods, this block has massive notching about 5-7cm long around the bottom of the bore and up the sides of the crankcase wall, my PAR rods are way bigger, I've had to notch my block even with 76mm stroke, and I'm worried that even at the 81mm stroke I won't be able to clearance the block enough to clear the rods without braking through into the oil gallery.
Ahhhh..... Decisions decisions, I should have just bought a car with a bigger bay and went 2J
6BOOST
Booooooring. You made the right choice mate and you know itOriginally Posted by 6BOOST
exactly!...whats the point of prooving that a 2j can make 800rwhp when it has been done 1000+ times before?Originally Posted by JustCallMeOrlando
plus when your old and retired, you can write the book 'HOW TO BUILD A TOUGH 1G'
which only people on toymods would buy
but i agree, why build a 1jz or 2jz when its been done to death.. what about getting the block sleved ?
Hamgatan says:
i pwn my momma
Was browsing Lindens epc last night and the lifters from a 1g were the same as 4a, 7m, and a whole lot of other engines, maybe theyre not 1g specific. The engines along with many many more also shared the same stem seals, and visually the 4a head and 1g head looked very similar.Originally Posted by 6BOOST
how much volume is there in the combustion chambers?
at 2263, you're only 147cc from 2400....perhaps that's how they worked it out?
Would be highly un-orthodox capacity calculation!Originally Posted by cush
Sounds like a trick bit of kit that 1g!
The 4ag has the same stem diameter, but much larger valves and they are about 5mm shorter, I have cut down 4AG Formula atlantic Ferrea valves in my race head. They may have done this, but I'd say they are made for the 1G, seeing as how they went to the extent of forging a crankshaft!!!Originally Posted by LeeRoy
Capacity is worked out from bore, stroke and cylinders, basically borexstrokex6, or:Originally Posted by cush
3.85*3.85*3.1416=46.56=Area of piston/bore
46.56*8.1=377.18cc=Bore*stroke
377.18*6 cylinders=2263cc.
Volume of the chamber has nothing to do with it, and like I said earlier, I have sonic tested 3 blocks, none would take 79mm pistons without leaving more than .5mm of wall thickness, or .020'
I don't like the idea of sleeved blocks. I'm sure some engines do ok, but I've seen far too many hassles to risk it. You can't get a head gasket(other than a copper) in bigger than 79mm bore anyway, and I'm not that fussed with 60cc of capacity, I'll just rev it another 1000rpm, she'll be rightOriginally Posted by byteme
I'd just like to say also, that I'm completely happy with the engine and in no way blame Import bits for anything, John was helpful and great, and I'm very thankful he let me buy it, I am only dispelling the "MYTH' of the 2.4 bit, as its a little bit of romour and fairytale I guess. I'll be getting some custom rods and pistons made and seeing what happens, I'll finish and run the 2.15 litre engine I have now and sort the car out, I'd say it will make 99 of the power I've got now. I'll use the HKS kit when I have everything spot and and holding together with 40psi up its clacker
6BOOST
how much you want for the complete head?
Well, cams are worth $850 at least, then you have HKS springs, valves, very nice port work and it will be faced, cleaned, and if need be seats cut and guides done, as well as new valve stem seals just to be sure, add those things together, and pm me an offer. Nothing stupid though guys, it cost me $3500 for my old 1G head and 6500 for my new head, I'm not going to "give" it away.
6BOOST
