Results 1 to 6 of 6
Thread: What sortve glue is used to bond boot skin to boot frame?
    1JZ FTW! Domestic Engineer chrisrundell69's Avatar
    Jun 2006
    south australia
    Default What sortve glue is used to bond boot skin to boot frame?
    ok the boot skin is coming away from the boot frame on my ke70 corolla and was just wondering what sortve glue i can use to bond it back together and where can i get it from? may sound like a stupid question but any help would be appreciated
    Past Cars: Blue TA22 2T, Green TA22 2TGEU, Orange RA28 18R, Green RA28 18R, Multicoloured RA28 18R, White JZZ20 Soarer 1JZ
    Present: Maroon GA70 Supra, FMIC, Adjustable Cams, SAFC II.......
    KE70- Stock as a rock.
    Default Re: What sortve glue is used to bond boot skin to boot frame?
    Are you talking about the carpet peices inside the boot on the rear quarter panels?
    If so, use contact adhesive. K&H do it in a 400gram spray can for about $10.00. You can use this for sticking carpet to speaker boxes/sub boxes etc.
    Nah, from my reading, it appears the boot skin is departing from the frame.
    Best solution, would be "Urethane" SupaCheap sell it as Sikaflex. Pump some between the frame and skin, and use some rags soaked in kero for cleanup.
    Never ever use acetic acid cure silicon's such as Silastic, that crap eats paint, and starts rust.
    cheers Chuck.
    MS51Crown Coupe,
    Jun 2006
    south australia
    Quote Originally Posted by ChuckLandwehr
    cheers Chuck.
    cheers chuck exactly what i was after +rep
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    HI
    Just sand out all the old shit and prime first,this seem to be the first place you get those nasty pin holes that stuff up your expensive paint job. and yeah sicka flex is the shit.
    I had shitloads of problems with crap boot lids on my CELICA.
    Jun 2006
    south australia
    You must spread some Reputation around before giving it to ChuckLandwehr again.
    cheers for everything guys
