i think they are different but im not sure.
i believe the 1j is smaller in diamater.
i konw that the 1j has a small flywheel which makes it very hard to find aftermarket clutches that will work.
latter,
sheepers
I am looking to import a clutch from the states. None of the clutch companies list 1JZGTE in the states . They only list 2JZGTE. Are the clutches the same ? Are the flywheels the same ? I may be after a billet flywheel as well.
Andrew V
Central Vic Auto Parts
Forum sponsor
www.cvap.com.au - Have a look
[email protected]
Ph 03 58 231911
latter,
sheepers
69 MS51 crown coupe. http://www.toymods.org.au/forums/sho...980#post835980
RA23 celica with 1JZ-GTE. http://www.toymods.org.au/forums/sho...sheepers+jza23
76 RA28 celica 1UZ, http://www.toymods.org.au/forums/showthread.php?t=12299
2JZ-GTE clutch and flywheel is different. 7M-GTE clutch is the same but the flywheel is unique to the 1JZ-GTE so you might want to source that from Japan. Another alternative is to modify a 2JZ-GE flywheel to accept a 1JZ-GTE/7M-GTE clutch as discussed in an earlier thread.
Norbie!
www.norbie.net
i can get pics/measurements on a R154 1jz fly if you require.
got one laying around
hello
Thanks Norbie . Thats the info I need. Looks like a local one is the go
Andrew V
Forum sponsor
[email protected]
Ph 03 58 231911
As norbie said, the 7mgte pressure plate and clutch disk are the same as 1jz-gte.
Flywheels as said before are different
