PM "wilbo666" as he has done this conversion to his cressida
Has anyone done this conversion?I need to know what pedal assembly I need and what tailshaft do I use as I need an extra 80mm longer shaft than the auto's.
Cheers Brett.
hello
Thanks for that PM'd him and he gave me the run down of what he done.Now the fun begins with the tailshaft.
Cheers Brett.
Bah mine is W55 goodness, not W50.Originally Posted by brett_celicacoupe
Close enough tho
Not going to use a 5spd have got a 4spd spare know that it is in A1 order(no difference bar does not have 5th gear).Plus I have thrown you into the deep end to another member on your conversion.Sorry bout that.U said u used a crummydore tailshaft?Did u use a centre bearing for this?Also did u use a 4M manual flywheel?
Cheers Brett.
I used a shortened commodore shaft with conversion uni's. No center bearing (eww and why would you want oneOriginally Posted by crowncustom
I used MA61/5M-E parts for the most part, flywheel included.
Your 4M stuff should work fine however.
