Results 1 to 8 of 8
Thread: turbo compressor housing question
    Default turbo compressor housing question
    Quick question
    Wanting to get a metal elbow welded onto my compressor housing while I have it off for polishing. Just wanting to check what sort of metal I need? I assume most turbos would be made of the same stuff but for reference it is a Hypergear TR44. I was thinking probably aluminium pipe and welded with a TIG by the looks of it.
    Doesn't "appear" to be a steel as it isn't all that heavy.
    Any help much appreciated. Can get pics if that helps.
    Chris
    QUICKEST 1JZ'S IN OZ
    Junior Member Grease Monkey Laurie D's Avatar
    Default Re: turbo compressor housing question
    Compressor housings are aluminium. Why would you polish it?
    Laurie D
    Thanks.
    Match the rest of the shiny bits in engine bay
    cast aluminium probably, so should have a fair whack of silicon content perhaps (for fluidity).. (does it look like ally?)
    someone with experience with welding to shit cast alloy will be able to recommend filler wire etc...
    Yeah feels like an alloy to me because of the weight. Good stuff, I know a guy who welds aluminium gates so I will grab some alloy pipe and pop around to his joint.
    Forum Sponsor Conversion King
    Dec 2006
    use a 4043 silicone rod and remember that you will have to hit it with about 130 amps for it to start and also prduce a nice weld.
    not sure of the size but try to match the orig o/d of the turbo or it will look like arse.
    linden
    Thanks Linden
    victoria
    where are people gettin gettin ally bends from? ive just welded up two donuts, whioch does the trick but if enyone knows where to source 90"s from that would be nice an easy!
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 12:02 AM
  2. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 09:18 PM
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  4. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 07:58 PM
