many people say Malpassi is not very good..
perhaps research thatbefore pumps?
pumps don't flow hp.. they flow fuel
what i mean is, at different pressures, different pumps flow different amounts.
there is a "high pressure" walbro that doesn't fall off in flow until a bit higher pressure, and then there is a bosch one that does even higher pressures..
if it is for NA, then maybe that is not a concern, but for turbo, it all depends on the pressure required (ie, 40psi+boost)...
on that note...rising rate regs are bad for turbo.. very bad...![]()
