Results 1 to 3 of 3
Thread: How many teeth on R154 speedo gear?
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Default How many teeth on R154 speedo gear?
    Just wondering how many teeth should be on the R154 cable speedo drive, it was out of a JZA70 if it helps.
    I picked up a cable drive gear from the wreckers which is 33 tooth, the electric one I already had in the gearbox is 31 tooth.
    Thanks
    Default Re: How many teeth on R154 speedo gear?
    http://akb.norbie.net/Public/Gearing.aspx
    Put all the relevant info into that and it will calculate which speedo drive gear you need.
    Gold Coast, QLD
    Ok thanks.
    JZA70 R154 with standard 4.100 final ratio should have a 33/10.
    MX83 with R154 with 3.91 final ratio came up with 31/10...
    The 33 tooth I have says 10\33 (top/bottom numbers) so it's obviously the 33/10...
    The 31 tooth says 35/31. So does this mean it won't fit? What gearbox uses the 35 drive gear instead of 10?? I'll try it anyway.
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 11:18 AM
  2. Toyota Manual Gearboxes and their Ratios (W, R, V, K, T, P)
    Last Post: 05-09-2012, 02:48 PM
  3. Replies: 2
    Last Post: 10-03-2009, 05:29 PM
  4. AE86 "Cusco" quick steering racks??
    Last Post: 02-06-2007, 01:13 AM
  5. Classic celica suspension TA23
    By WindeX in forum Tech and Conversions
    Last Post: 12-01-2007, 09:54 PM
