not directly
the only 5 stud hub that will bolt on to the corona or celica hub is the MS65
i do recall someone modifying a ms85 hub to suit try searching for it
Ive done a search and have had no luck
Ive found an MS85 crown a mate pushed into a gully on his farm
I want a 5 stud pattern and am wondering if I can use the hubs and calipers on my XT130 struts in my RA23 ?
Thanks
not directly
They bolted onOriginally Posted by rob
Saying that I haven't driven on then though
http://www.toymods.net/forums/showth...highlight=ms85
This was all I got with the search
as in the ms65 hub bolts on the celica strut.
So its all good then ?Originally Posted by The Real Roadrunner
you do know the difference between a 6 and an 8 dont u?
As has been said MS85 hubs can be modified to work (machine to suit other bearings, as a note the conversion bearings are significantly / lots more expensive). Heck I even did a document up showing what had to be done...
MS65 is the bolt on way to go
NoOriginally Posted by rob
Thanks mate thats what I was after where is the doc?Originally Posted by wilbo666
Btw the thread this was listed in was titled (Great engrish in the title eh bah)Originally Posted by badboybubby
"Guide: Using Modifying MS85 hubs to fit MA61 etc"
And came up as the 7th search response when I searched for "MS85 hubs" (To help you improve your searching skills in the future ).
The pdf should still be
PDF HERE <CLICK>
As it says it is just a guide, check it all yourself before you make it happen
Also if someone wants to add it to the techdocs by all means that would be good (I don't rate that free hosting all that much...)
Anyone got some MS65's ?
good luck
Black Betty >HERE!<
(\__/)
Im sure people have them, but I doubt they want to part with them
Originally Posted by CLG
