gen 3 1g clutch is 240mm, im sure it would be bigger and better, I think from memory you can use the 1g clutch
ok i have got a 3tgte in my ta22 i have searched and searched and found so much info i done know where to start about the clutch part of it can i just use a 1G clutch or do i use a 3tc clutch or what. thanks any info will help
RA23 1JZ VVTi 373hp - SOLD
12.4 @ 110mph
THE EVOROLLA262.9hp - SOLD
c budge, the 1G clutch and pressure plates, are fairly universal in size across the Toyota range: 18RG. 2M, 3TGT, etc.Crowns, Celica's, Hilux's etc.
First step, find a flywheel 3T-GT, 1G-GTE with the locating dowels way out near the edge. Second step, go and see Trevor, at Australian Brake Sleeving in Qbn.Trevor sells Exceddy clutches, and a high clamping force Hi-Lux 4WD pressure plate, which will do the job nicely. Trevor can also machine your flywheel .
cheers Chuck.
MS51Crown Coupe,
well i will be pulling out the t50 today so i will go out tomorrow and have a look wat they say and i will let ever1 know wat i use thanks
um, you will need another tailshaft too....different length and different splines on the output shaft of the T50 and W5x
you'll also need a modded rear mount plus ; if you're using a G series bellhousing to do this then the rear mount will actually be too far back for the factory holes in the floor ; hence you'll need to get creative with your welder and move it back a bit...
agreed,Originally Posted by Grega
when we did LeeRoy's there was a fair bit of work involved in getting it in.
definetly not a 1day job unless you have a welder and are very creative.
linden
also ; the shifter position may require massaging of the stock T50 hole.
TA22 auto cross member and a couple of 300mm long pieces of angle iron, drill 8 holes, and you have the box mounted. TA22 auto tailshaft is a perfect fit, spline wise, and length wise. Angle grinder with 1mm thick cutting disc, to remove rear section of tunnel top for the shifter.
cheers Chuck.
MS51Crown Coupe,
ok pulled out the old box today.. put the new one in for a test fit i did need to cut the hole and will need to mod the mount.. so i will need to get an auto tailshaft and mount i will get some pics up.. also the 3tgte locating dowels r way out near the edge. (3 of them)
