Results 16 to 29 of 29
Thread: What is my rocker cover off
    Junior Member Domestic Engineer 1jz68u's Avatar
    Default Re: What is my rocker cover off
    Haha this is heaps funny no one has any idea.
    as for changing oil, it comes out the bottom as usual and goes in through the breather hose that is attached to the rocker cover.
    still no idea why it was done this way though, unless it is a GTE that has been re built without a turbo or something silly like that?/? i have no idea either......
    but if people that have the different gen GE/GTE's put some pics up we should be able to work it out.
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
    the always broken 165 Carport Converter piggy's Avatar
    n.t
    well it looks the exact same as mine except i have an oil cap but ill have to get some one else to take the photo as i leave but i think almost all the gte ones are the same
    1974 TA22 Celica the new project
    2002 UZS171 Crown daily
    st165 white forged gen2 3sgte 264deg cams, 1000cc injectors, side facing plenum, GT30, CBR600 COP, 205 gbox, diff and calipers, haltech ecu,coilovers, 3'' exhaust, water meth injection 235AWKW @ 22psi 12.29@117MPH 1.885 60'
    Gen 1 3sgte ... no more arguing
    Was prob cut down so the bonnet could close etc
    Black Betty >HERE!<
    (\__/)
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    no look at the oil overflow port... i think its defiantly a gen 2 3sge.. it looks exactly like mine..
    the threads for wiring and the lack of two casts and the toyota writing .. Def gen 2 3sge
    i dont know looking at the pic, the ridges are missing are missing on mine.....
    Glenn
    Cheers, Jason
    what is the best way to find out what model engine it is? if there is any cause that might solve the problem.
    Glenn
    Cheers, Jason
    Read off the engine number, find the head part number and find the part number of the cover. Take to Toyota and they may answer.
    Regards
    Rodger
    That valve cover is definately not a gen1 3SGE and definately not a gen2 3SGTE.
    Thinking its a gen1 3sgte, but i've never owned one of those motors so i cant speak from personal experience.
    If you compare the gen 1 3SGTE to the original photos you'll see they are different for the reasons blakeg has outlined. So I guess that has narrowed it down, its a gen 2 3SGE cover thats been cut and welded
    1jz68u - Grab the part number off the head and I'll try it in the EPC
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    It is GEN2 3S-GE and thats what you do to fit them under a bonnet RWD.
    But most of us put the oil cap back, just lower.
    The dizzy looks like GEN 1 import upside down.
    MATT.
    umm silly question, where is the part number on the head?? i can get the part number off the dizzy to see what series that is.
    they should right it on all the stuff that would make it so much easier
    may limit interchangability but hey...
    Glenn
    Cheers, Jason
    Should be on the side of the head and should start with 88888-...
    ([][][]II--LT--II[][][])
    ok im stupid, exhaust or intake side? would it be where i cant see it? eg. under ex manifold?
    i cant find it.
    also have the part number for the dizzy its 19400-88363
    unless i got the wrong number in which case i think its missing some numbers.
    Glenn
    Cheers, Jason
    Engine number is on the side of the head,above where the gearbox bolts on. Since your 3sge is mounted North/south it might be hard to see!
  1. 2TG Rocker Cover Guide - With Pics
    Last Post: 28-05-2015, 09:56 AM
  2. 3sgte rocker cover
    By gee120 in forum Tech and Conversions
    Last Post: 05-08-2007, 10:24 PM
  3. 2tg half moon rocker cover gasket
    By auzzi_17 in forum Tech and Conversions
    Last Post: 26-10-2006, 04:53 PM
