Results 1 to 15 of 21
Thread: Where should BOV get its signal from?
    Hoppers Crossing
    Default Where should BOV get its signal from?
    Folks
    Interested as to where the BOV should get its signal from?
    Before the throttle body or after the throttle body?
    Logic tends to suggest the BOV's purpose is to vent pressurised air in the inlet tract post the supercharger/turbocharger but before the throttle body.
    Any thoughts/comments/what do factory cars do here?
    All replies appreciated.
    Grega
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default Re: Where should BOV get its signal from?
    doesn t make sence to me grega,
    you BOV is always going to be before your throttle body isnt it??
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Forum Sponsor Conversion King
    Dec 2006
    bov goes between turbo and TB but the signal should be after the TB on the plenum.
    linden
    Linden has it on the nose. The BOV opens on vacuum from when the throttle is shut. It lets pressurised air go from after the turbo to before in the case of a plumbback.
    Hoppers Crossing
    thanks guys, i know where the BOV goes and what it does. i'm just questioning where the signal for it comes from.....but thats answered and makes sense.
    um dont mean to sound stupid, but whats this signal you speak of?
    Hoppers Crossing
    hash when i say signal - i mean vaccuum or pressure from the inlet manifold dude.
    Dec 2006
    Quote Originally Posted by Hash_ra23
    the small vac line that runs into the top/side of the bov,
    its what makes the bov work ie if there is boost press it closes the valve, if its got vacuum it opens the valve.
    linden
    From the post title i thought you had an electronic BOV for a sec.... hehe
    My rotary goes Buuuuuzzzzzzzz!
    indeed, had me quite a bit confused too... a 'signal' tends to suggest something electric/onic, where a BOV has nothing of the sort. how the BOV works (and I had to find this out the hard way) is by the vacuum line getting enough pressure to pull the piston on the BOV in order to get it to release the charge air either to the atmosphere (atmo) or back into the air intake route (plumb-back). mine, a GFB StealthFX, was supposed to be working quite well but it wasn't, and the only way I could get it to work was by talking to the dudes at GFB and having them suggest to me the proper route of the vacuum lines, because neither the BOV nor the wastegate were working.
    about 1m of silicone hose and a couple of T-pieces were needed to set things straight again, and for the BOV and wastegate to actually function in the correct way. if you shifted gears before, it sounded like a bird-fart which was rather unimpressive... but sorting out the vacuum plumbing was the cure to all the ills.
    TRIKKE | Video
    There should be a vacuum line running from your plenum/intake manifold (after the throttle body), across to your BOV. What motor are you running? If running a 1JZ, you'll have a small metal air line that runs along the back of the motor near the firewall.
    244rwkw / 328hp @ 18psi
    Quote Originally Posted by Andrew162
    Signals have been around since long before electricity was discovered. You have signal flares, signal flags (used in semaphore etc). A signal can be anything that indicates something, whether it be an electronic signal telling the ECU how far open your throttle is, or a vacuum signal telling your BOV to open. Could be a kettle wistling to signal that the water inside is boiling (for those who grew up with gas stoves)
    Back OT... I thought that there would be two signals coming in, before and after the TB, indicating a pressure differential... obviously I am wrong... so thanks to those who asked the question, and those to answer. Goes to show theres no such thing as a stupid question (other than "how do I make my XD foulcan look sexy"... cause that just cant be done )
    Hoppers Crossing
    Cool Re: Where should BOV get its signal from?
    OK, flame away
    I actually have something a little different.
    Believe it or not its actually a Toyota Lexcen
    Now, the reason I asked is because I wasn't sure on how the BOV actually works. I knew it vented excess pressure from when the throttle butterfly closes between the supercharger and the butterfly ; but ; i thought it only did this thru a pressure signal (theres that signal word again) which in turn caused the BOV to expel the pressurised air. I was wrong. Its vaccuum in the plenum thru the closed butterfly which opens the BOV to expel the pressurised air.
    Andrew ; thanks for your pic. Now for the 68 million dollar question.
    With a wastegate ; where does the signal for that come from? Plenum or pre throttle body?
    Wastegate signal: from the compressor housing or close to it.
    My KE25 thread
    Hoppers Crossing
    YLD......even for an external HKS gate? its got two ports on it ; one on the side ; one on the bottom...
  1. Should I add a BOV to my 1ggte?
    Last Post: 10-04-2008, 08:39 PM
  2. Fault Codes
    By Duk in forum Tech and Conversions
    Last Post: 24-07-2007, 08:42 PM
  3. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 10:11 AM
  4. tial BOV not operating correctly
    By EVOSTi in forum Tech and Conversions
    Last Post: 06-09-2006, 05:50 PM
