Results 1 to 9 of 9
Thread: Anyone bought a whiteline swaybar?
    Default Anyone bought a whiteline swaybar?
    Hi guys,
    I've just bought a pair of whiteline swaybar for my Sprinter yesterday. Anyway I notice that the front one only come with the mounting bushes whereas the rear one came with both mounting and end bushes.Is this normal? do they expect you to reuse the old rubber bushes on the car?
    Also anyone got a picture of of what the end link part look like with the bar installed I just want to be sure that I put everything together correctly because there is a few rubber rings that came with the rear bar that I'm not too sure where they should go.
    Thanks you
    Default Re: Anyone bought a whiteline swaybar?
    the front shoulda come with the bushes as well, ?? maybe u got ripped,
    also good investment the whiteline sway bars are F#ckin awesome
    Yellow Belly Black Snake Backyard Mechanic Sprinter-Saurus's Avatar
    New South Wales
    I recently purchased front and rear Whiteline swaybars and the front one only came with the 2 mounting bushes. I just re-used the ones that were originally on the control arm as they were still on OK condition.
    I'll try and get you a pic if the rear one ful;y installed dude.
    Cheers, Daniel.
    when i got my swaybars i paid extra for the bushers, but i think that they came with them anyway an the supplyer just kept the money.... none-the less you should be able to use the old one if the sway bar isn't any thicker, in the other case where it is you need to pick up new busher to the sway bar will not be able to move. and yes that would be grease in the packet that is white if you got that too.
    good luck, i agree whiteline make very good suspension gear.
    SYD
    when i got my fron bar it only came with the bushes which sit under the d clamps,
    When i got my rear one it came with the bushes under the d bolt and the bushes at the over end, thought this would have been because u dont have existing bushes as there is no swaybar there already. (ta22 didnt come out with a rear swaybar)
    unsure if sprinters come stock with a rear bar??
    Sprinters have a stock rear bar, but commonly the bushes on the lower end are so shagged that you cant install the new bar without replacing them.
    GT4 Insane Backyard Mechanic 1gt48u's Avatar
    generally they only supply new "d" mounting bushes with the new
    swaybars to fit the existing brackets
    sometimes they do supply additional bushes/bolts/brackets depending on
    application when required, otherwise use your original parts or indeed order new ones
    Troy
    ST185 GT4
    Yeah my white line only came with the D clamp bushes aswell.
    yup rear comes with the 'd' and the chassis side bushes but the front only comes with the 'd' bushes...
