Alot better buying a JZA70 manual half cut mate.
Hi all,
I have just bought a 1989 GZ20 Soarer its got a 1GFE in it, I have always been a fan of the Z20 soarer's, I have been looking through this forum for a while and I see its pretty common putting in a 1JZ, I'm looking at doing a engine conversion as the 1GFE just needs to go by the way this is my first post.
I have read roughly through a few threads of which the conversion has been done but not all of them as there is a few with many pages, so I got a few questions.
- I think I have read that the 1JZ will sit straight in the MZ20 crossmember without much trouble, would this be the same with the GZ20 crossmember.
- I know the JZA70 supra halfcut is usually used to source the 1JZ, is there any other toyota that I could use to do the conversion, I also want to to do a manual conversion.
thats it for now but I got a question about the auto, I want to do a service on it, I tried to source a auto kit from repco but they had non listed for my car, I'm guessing that the auto behind the 1GFE would be the same as a 1GGTE auto, where could I source a auto kit.
-Sleeper 2J + R154 X83
-GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
use the jza70 halfcut that way you have everything needed for the conversion apart from the fuelpump and exhaust.
linden
Yeah was planning on searching for a JZA70, I was told that they are getting hard to find now, also with servicing the auto I tried searching for it, can't find any information, does anyone have a part number for the auto kit.
I also might as well ask this, has anyone put a 1UZ-FE in a z20 soarer.
for a jza70 cut call sss automotive in girraween nsw they have 6 coming over in man form.Originally Posted by bigpitty1
the 1ggte auto is an a340 so check your compliance plate to see what yours is.
if its a340 get one for an mx83 as they should be the same.
linden
I'll try that, thanks
just to re-iterate...the easiest way to do it is with a JZA70 halfcut....cheapest too...there are guys in perth getting 1J convos into soarers done in under a weekend!
Project Soarer II - Sold
Evo 5 - The silver fruitbox
.......excluding me of course
yeah as everyones saying... JZA70 halfcut! take it from me, i learned the hard way that unless you have a halfcut you're going to be up shit creek without a paddle trying to find bits you need.
theres a few members rides threads (mine, coff33's, mr_1jz's old car, etc..) that have 1JZ info regarding the conversion.. so yeah feel free to ask us anything thats not in there.
basically you need the halfcut and the jza70 2 piece tailshaft. you use the front half of the supra tailshaft to bolt the yoke up to the box and the soarer rear half back to the diff. speaking of diff, check your axle code on your firewall as well, if its G254 go find another diff as well coz i tell you even though it will still run... 1J + 4.551 open centre is not fun... its downright ghey with aides. also make sure you do a refresher of the main bits before you bolt the engine up, that includes oils, fluids, timing belt, serpentine belt, fuel filter, plugs and depending how far you want to go, a few seals here and there too.
oh and you'll definitely need new mounts. all jza70 halfcuts that land here have screwed mounts. PM Ezra for a set (byteme), they cost about $200 for the pair but thats shitloads better than getting them new from toyota at $560 a pair. also theyre semi solid state urethane. i run them in mine, as does coff33 and theyre the dogs bollocks.
by the way that bit about a MX83 auto being the same, can someone verify that as im pretty sure they have different torque converters.. the one for M engines and G engines is completely different even though the box is physically the same. id be more inclined to think it was the same as a gx81 cresta/mark II/chaser
JZZ20 1988 Soarer GT Twin Turbo 1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
yeah but your conversion not happening as planned was a direct result of your car revolting against its gheylawd owner!
dont look at my conversion for advice, i did it the hard way...I even made custom mounts...
JZA70 halfcut...swap it all over...winner
I plan on doing the conversion myself, I'm a mechanic at the holden service department where I live so I have a whole workshop to use which should make things a bit easier, with the diff will the JZA70 fit, I want a LSD, I'm not a big fan with open centre even thou is not a problem at the moment as the 1G-FE struggle to spin the wheels even in the wet.
Also this 1G-FE is the second motor in this car, I bought it like this, I was told that the original motor overheated and the head warpped so its now got a 1G-FE so I picked up my soarer pretty cheap, body is still in pretty good condition except the paint is starting to crack on the bumpers.
1GFE was available in nearly every car that a 1G was available, just not many people took the option.
