So unless you are building an engine that is so highly strung it gets rebuilt after every race meet, bucket and shim will give you the best result?? At the RPM a street engine (even a wild street engine) will rev, a good choice of valve springs can do away with the shortfalls of the bucket/shim design and render the ducati design a waste of time for a car engine (motorbike engines rev a lot higher, so Ducati have a reason to use it).
As for the question of shim over or shim under, I would say shim under. Also, you can get self adjusting buckets (basically hydraulic lifters/tappets) such as those found in the RB26DE engine. I dont like anything such as this as the oil galleries are so small that minute amounts of impurities in the oil (the junk that gets through most oil filters) will cause them to block up after a time, and they are an expensive pain in the a-hole to replace. But yeah, shim under has the advantage that the shims are wholly captive, and it would take a valve spring failure or similar to unseat them, whereas shim over bucket the shims have been known to be flicked out by lumpy cams.
