Results 1 to 15 of 20
Thread: Candle buring smell when i give it some
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Default Candle buring smell when i give it some
    howdy peoples since i did my turbo conversion i get a candle/wax buring smell when i give it some for a minute or so. I've checked the engine bay and nothing near the turbo or manifold seems to be melted or close.
    Does anyone know what this smell could be?
    Previous Rides: JZA80, GA70 GT, RA63 GT x2, TA61 GT, TA63.
    Default Re: Candle buring smell when i give it some
    how long since you did the conversion?
    could be as simple as the excess flux and gasket goo burning off the exhaust, especially if you're in the first few hundred kms or so.
    W.A.
    proberly been 500kms but didn't use gasket goo used proper 1g gaskets from toyota
    fresh welding always stinks for a while, although at 500kms you should really be at the end of the "stink in" period
    take the candle off the manifold you noob ;P lol, jokes
    maybe try hitting all the trubo/manifold with brake cleaner and wash off all evidence of oil/grease from greasy hands....
    no PLASTIC bags burnt onto the exhaust?
    blake
    hope you took the bungs out of the turbo
    no oil leaks?
    mine always smelt a bit funky. my oil drain always leaked around a silicone hose and made toast of itself on the manifold...
    W.A.
    i did have an oil leak which dropped onto the manifold but i fixed it today, maybe it's just the rest of the stuck oil on there smelling.
    Quote Originally Posted by Jackel
    well thats most likely it, no matter how well you clean it, you will have a smell for a short while,
    but still keep an eye on it for a while, if the smells still there in a few days, go over the whole car, any HOT parts...
    blake
    how new is the exhaust?
    ...... butt scratcher?!
    Junior Member Conversion King deviant's Avatar
    wa
    All your exhaust heat shields still in place?
    If not you could have melting underseal and even worse than that melting carpet inside the car!!
    As mentioned above you could have picked up a plastic bag off the road. They make a bloody mess and really stink. Half an hour with a scraper will sort it though.
    Quote Originally Posted by S2K
    Would a VTEC limiter be a helpful device?
    W.A.
    well found the problem the gasket on the oil line for the turbo wasn't tight enough and is spitting oil on the manifold when i give it shit, might need a thicker gasket or a goo. What goo can withstand being on a turbo?
    hi-temp red should work...
    W.A.
    would i be able to aquire this from supercheap or repco?
    yes6543210
    autobarn is my preference
    W.A.
    sweet dude
  1. Fuel smell under boost/cruising mz20 7mgte
    By Kedderz in forum Tech and Conversions
    Last Post: 19-01-2007, 07:51 AM
  2. i smell bad after i drive my car
    By KLR16V in forum Tech and Conversions
    Last Post: 19-07-2006, 07:57 AM
