Results 1 to 6 of 6
Thread: Over heating
    Default Over heating
    Lately my 85 rolla has started overheating...
    i have discovered that my radiator fans do not come on... thus causing my car to get hot.
    I have checked the fuses and the appear to be working, i do not know what else i can do...
    is there anyone local who could maybe have a look at it for me?
    Dont get mad get money!!
    ditty man Grease Monkey
    wa
    Default Re: Over heating
    Quote Originally Posted by GMSkitz
    how long did you wait for the fans to find out they wont come on?? check your relay's also, should be in the fuse box in the bay.. connection may be dodgy or somthn, try either cleaning connections or pushin them down over the terminals... but more than likely relay prob if there both not working.
    hey man. i had same problem for like the last 3 months
    -so ur fans dont come on at all? did it over heat in traffic or it over heated whilst moving...??
    -try unplug the thermo switch, and does the fan come on?
    -if it doesnt come on, check if the fan starts up at all... run a temp wire straight from the fan to the battery.
    -if the fan doesnt work thats ur problem. if it does than check if the a/c fan comes on buy turning a/c on... if it doesnt come on then it could be ur engine main relay(that was my problem)
    -if u dont have a/c then find sum1 wif a rolla like urs, and swap each rellay over untill u find one that doesnt work.
    so step 1, ull work out if its the thermo switch, if the fans dont come on wen u unplug them then it could be sumfin further down the track.or it could be both
    step 2, u check to make sure ur fans actualy work. if they do then u move to the relays.
    step 3, check ur relays. if its none of the fan ones try the engine ones.
    it should work, if it doesnt then maybe time for a auto elec, or sum1 else might help ya.
    JZA023
    Unplug the temperature switch from the bottom tank of your radiator... the fans should come on when the ignition is on and temp switch is unplugged.
    If they come on then your fans / relays are fine and you may have a dicky temperature switch... if they don't then check all of the relays and fuses.
    i think the thermo switch is on the thermostat housing wif the rollas. atleast it was on mine. easy enough, check both spots...
    JZA023
    Thanks for the help guys....
    I't look's like i need to take it to a auto elec, because i honestly have no idea what the heck im looking at....
  1. MA70 heating problems.
    By EldarO in forum Tech and Conversions
    Last Post: 02-02-2006, 01:35 PM
  2. silvertop 20v over heating
    By deaf_rattle in forum Tech and Conversions
    Last Post: 27-01-2006, 10:51 PM
