Results 1 to 9 of 9
Thread: Can anyone PLEASE help me? rewire fuel pump
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Dec 2006
    Default Can anyone PLEASE help me? rewire fuel pump
    Howdy guys, need all of use help if use can.
    can anyone tell me how to rewire a fuel pump and if i need relays and other stuff?
    the car is a GZ20 with 1JZ
    any help will be awesome.
    Much appreciated.
    Heng.
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Default Re: Can anyone PLEASE help me? rewire fuel pump
    Whats wrong with your existing setup? or are you installing a new setup?
    Dec 2006
    Quote Originally Posted by Kebin
    cant find the old wires going behide the glove box but if anyone knows that be great. just saves me time to rewire a new one.
    so i thought i might as make a new wiring for it but not to sure how and what to use
    Check if you have an black and yellow relay with "open circuit relay' written on it. That would have the old fuel pump wires going into it. on my 3sgte and 4age the relay was mounted on my ECU.
    heres a link: have a read around this http://www.rollaclub.com/faq/index.p...g_Relay_Wiring
    Quote Originally Posted by Aust162
    There is also a dedicated Fuel Pump Relay on some cars. It is connected to the Circuit Open Relay, as on my 1GGZE install.
    The power to the pump is usally a blue wire.
    Check my tech thread on relays:
    http://toymods.net/forums/showthread...uel+Pump+Relay
    Peter
    Consult a wiring diagram and/or TSRM. Shouldnt be hard to trace your existing circuit and graft it in. Fuel pumps should never be run solely off a circuit opening relay. Use a seperate relay to supply power to the fuel pump(s).
    Exactly! Good advice Kebin.
    Peter
    GZ20 ... Blue Wire Red Trace leaving the 'Circuit Opening Relay'
    should red 12volts+ on a multimeter when you turn the key to Start.
    Black Betty >HERE!<
    (\__/)
    Dec 2006
    Thanks alot guys
    much appreciated
    Where would the open relay be located on the car??
    Thanks, Heng
  1. Replies: 20
    Last Post: 08-08-2007, 09:06 PM
  2. sw20 non turbo not starting (fuel pump, filter ???)
    By purple5ive in forum Tech and Conversions
    Last Post: 23-07-2007, 08:45 AM
  3. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
