i know the early sw20's had a twin piston caliper.. i coudlnt tell you disc size although i know early sw20's were fitted with 14" wheels so it is more then possible they fit on the 258 rotors as much bigger nad you wont get them under 14".
the celica twins ive got fit under aw11 14" stock wheels just fine.. tight but fine.
ive got them on a 258x22mm rotor and its a perfect fitment. (aw11 factory size rotor)
the superstrut ones might be a different rotor and caliper moun ting braket putting them furter out but the same pad ? i know the later model st185 single piston calipers use a 278mm rotor.
ive never seen a set of superstrut ones so i really couldnt say. that said if you look up in the project mu catalogue it should give you a part number plus a printout of the pad shape you can compare.
