I have a box out of a 98 2wd hilux work mate with the fuel injected 2 litre.it has the steel plate in the middle.any body know what box it is?
cheers, Alan.
The steel plate type is definitely stronger from personal experience, sure we can argue each box has been treated differently etc etc but until someone buys 2 brand new NOS boxes, builds a test rig that runs them for 200000km at various loads I think the best we can go off is experience. My personal experience with 55's is they break easily. 58's (steel sw) have lasted much longer. The steel plate could be an indication of other internal changes also. Even 1.5" of alloy will flex somewhat (someone wanna do the math?) and even small flex when it comes to gear mesh can cause big problems.
cheers, Alan.
If you pulled it out of the original vehicle, then it will be on the build plate (thanks Norbie for the pic)
The basic layout is the same for similar years. This is from an Aristo and second from the bottom you have "Trans/Axle A340E A01A". In place of the A340E, you should have your transmission code and it will say what the original gearbox is.
More than likely being in a hilux it will have different ratios suited to towing. And if it is the original gearbox, searching either here or elsewhere would be able to tell you what you should find.
Thanks for that Big Zop, it has G54 for the trans code, so what would that be?
Cheers, Alan.
Not too familiar with Hilux's, so you are going to have to look around for that answer.
I don't think the steel plate version is any stronger at all, infact its got nothing to do with what the plate is made from thats causing them to break.Originally Posted by hemi twofifteen turbo
majority of ppl are stripping teeth off the input shafts, this is caused by the front layshaft bearing or input shaft bearing collapsing or wearing to the point where they seperate enough to chip the teeth off, this is obviously in a completely different area to the sandwich thus i dont think the plate material is the problem.
im about to tear one down to have a good look at what can be done to increase the strength in the front of the box but ill post up my findings then.
linden
Originally Posted by WHITCHY
I tend to agree with you linden.......i mean it makes sense really. I dont think the sandwitch plate had anything to do with the boxes strength. There could be some flex issue but im doubting it.
When i break mine it will be straight cut gear set![]()
Aren't straight cut gears weaker being that they take the load on a smaller surface area? I thought the only benefit of straight cut gears is reduced drivetrain losses again due to the reduced surface area of contact between the gears?Originally Posted by 30psi 4agte
Glen
correct on the first bit, yes they are weaker but only in the teeth engagement.Originally Posted by GT1978
the second part is half correct, its not frictional losses from the teeth but the fact that the layshaft and mainshaft are trying to push different directions and load up the thrust bearings during acceleration and deceleration due to the helical cut on the gear.
linden
Herringbone gearset FTW
Originally Posted by wilbo666
Is that a brand? got a link or a webite?
- KE70 Corolla Dx -
- 500hp+ 7AGTE 20V turbo -
- MRS/Hayabusa turbo **sold**
No, its a type of gear (like a V instead of a straight line).
He was having a dig because noone makes it but would be the best of both worlds - the load carrying capacity of a helical along with no thrust loads of the straight cut. But cost more than both.
Herringbone -![]()
I wasn't saying the steel sandwitch type was stronger due completely to the steel plate, -- but only in my experience the steel plate type has lasted longer. The steel plate could be a visual indicator of other internal differences. Has anyone noticed a difference in strength between the steel and non steel boxes, as I believe I have? All the 'heavy duty' boxes seem to have them? I've only ever broken gear teeth also. As for the teeth stripping (don't take this as pushing the flex argument too much) but flex = bearing side loading = more stress on bearings = accelerated bearing wear = gear teeth stripping?
Actually cuzzo it is a gearbox code. used in 4wds generally.Originally Posted by cuzzo
if it was a diff code it would have 3 numbers ie G342 etc
