Results 1 to 5 of 5
Thread: Wiring ISC Valve
    Default Wiring ISC Valve
    Hey all,
    Ok just for a quick background I a wiring a Wolf3d V4 into my Cressida running a 7MGTE..
    What I need to know is can the Wolf run the ISC with its PWM output or to put it another way the 4-wire ISC valve the 7M uses is it a PWM operated valve or is it a stepper motor (which the wolf cannot control)? Below is a link to the wiring diagram, you can see the ISCV located 1/3 the way down the page in the middle..
    http://www.cygnusx1.net/Supra/Librar....aspx?S=D&P=34
    Thanks for any help,
    Marc
    Default Re: Wiring ISC Valve
    Quote Originally Posted by TheDarkRaver
    Hey all,
    Marc
    7mgte is a stepper type ISCV.
    PWM won't work directly.
    As a suggestion it might be easiest to get a PWM type valve off an XF falcoon or similar (I think that is the one?!) and adapt that in
    Thanks for the reply, I figured it was a stepper motor from the diagram..
    Does anyone know what the 2jz uses? As I am planning on fitting a 2j plenum very shortly so might just put up with no ISC valve until then..
    Marc,
    Pretty much all Toyota 6 and up cylinder motors use stepper type.
    Most 4 cyls use PWM
    I am using a 4AGE 20V ISCV.
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 11:30 AM
  2. 2TG valve guides
    By merc-blue in forum Tech and Conversions
    Last Post: 24-10-2006, 10:43 AM
  3. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
