Page 5 of 24 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 346
Thread: GT35R on a 2JZ-GTE
  1. #61
    Default Re: GT35R on a 2JZ-GTE
    Don't be silly.
  2. #62
    Oh well big single conversions are never cheap. At least the hard stuff is done! Coming soon: skids.
    Pics before skids....then pics of skids
    Don't be silly.
    good boy norbie
    now run along and rip some external gate skids please
    video plz
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  4. #64
    So I bodged up some water lines and stuff and took the car for a spin tonight. It felt like it really wanted to go but I had a few dramas with hoses popping off, and the boost gauge kept giving me grief so I didn't want to step on it in case it tried to spool up to 30psi and pop the engine (unknown spring in the eBay wastegate). I was just getting it all sorted when I noticed the charge light on the dash... it seems the alternator chose this moment to shit itself. No more driving until I can source a replacement alternator.
    So, who has a spare?
  5. #65
    turbo-a Grease Monkey
    queensland
    are they anything like a 7m alternator? if so ive got a couple..?
    Turbo-A lives here!
  6. #66
    7M alternators and 1J alternators share the same guts but differnt casings norbie...if 2J and 1J are the same then a 7M one should suit your needs
  7. #67
    Have you taken your existing alternator apart to see what went?
    You might just need a set of brushes / regulator...
    btw my 2jz has a different plug to my 1jz, not a big deal, just something to mention...
    The alt is probably just brushes. It's a worthwhile exercise to pull them out and extend the conductor (free - by heating up the solder and pulling the conductor out slightly) or replace them.
    Mos.
  9. #69
    Sourced a temporary replacement alternator, car is running again. It turns out the wastegate is set at about 17psi and DAMN is it FAST! Sounds pretty angry with the screamer pipe too.
    I pulled the old alternator apart, brushes looked ok but it was full of black sludge thanks to my oil-dripping 2JZ. I degreased it good then bench tested it with a power drill and got a few volts out of it. Would that suggest it's working OK or was my bench test worthless? Obviously it was turning far slower than its normal operating range. I just want to know if it's worth putting it back in for a proper test, or if I should just send it off for a rebuild.
  10. #70
    Sound good
    Did you supply power to the IG and S terminals?
    I'm not really sure what rpm they start working at - the drill might just get enough rpm do to something.
    Mos.
  11. #71
    I just connected a multimeter to the big power outlet bolt thing with the negative on the body of the alternator, then spun it as fast as I could and the multimeter read about 2.6v. I didn't understand what the 3 pins on the back were for so I ignored them - I thought that was just something to do with the charge light? I don't understand alternators.
  12. #72
    User Conversion King
    NWA
    one pin is for the charge light, one is to supply power to generate the field and one is used to determine battery condition.
    for a bench test you would need to connect IGN, BATT, alternator body (earth) and something as a load. maybe an old headlight? you would want to test if the alternator can supply current
    full charging RPM for the alternator would be about 3000rpm at a rough guess
    hello
  13. #73
    Forum Sponsor Conversion King
    good stuff, what rpm does it come on at?
    does it feel alot laggier?
    linden
  14. #74
    Lag is similar to the original turbos in non-sequential mode. Starts making boost at 2500, 5psi by 3000, full boost before 4000. I'm very happy with it - if it came on boost any earlier it would just wheelspin all over the shop.
  15. #75
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    vids vids vids vids vids
  1. 2JZ Water Pump onto 1JZ
  2. 1jz to 2jz
  3. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
  4. 1jz vs 2jz heads
