Results 16 to 28 of 28
Thread: Error code 52 - Knock Sensor Signal.. 1JZ-GTE ....need help
    AU
    Default Re: Error code 52 - Knock Sensor Signal.. 1JZ-GTE ....need help
    Quote Originally Posted by sideshow
    just get a multimeter and measure for resistance between wires from knock sensor and ecu
    have u checked to see if wires are connected to knock sensors
    nup not yet, got to dark outside.. I will have to do it tomorrow night after work and then see how it goes from there.
    Cheers for all your help
    p.s. will it do any damage driving the car with the problem?... the car seems to run exactly as before... its not running in limp mode.
    Junior Member Carport Converter 4agte's Avatar
    i ran my gze with a broken knock sensor for some time sill made good hp when the aftermarket ecu was installed however its not a 1jz
    AU
    Quote Originally Posted by 4agte
    Cheers sounds promising for the interum... anyone else got any input?
    i had the same thing as 4agte, the knock sensor on my 4agze broke (i knocked the top and moved it), every time i drove it the light came on but it still ran fine,
    the only thing i suspect is you won't do any damage to the engine, but if it does knock the ecu will not pick it up and won't go into the preventitive measures to stop it
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Junior Member Backyard Mechanic manny's Avatar
    DTC 52 is open or short in knock sensor number 1 - the one at the front of the engine above the aircon pump.
    DTC 55 would have indicated knock sensor number 2 located at the rear above the starter motor which would have made more sense as you were disconnecting the heater hoses very close to it... unless of course the plugs between No 1 and No 2 have been swapped at some point.
    Check the wiring from the sensor to the ECU for continuity once unplugged on both ends.
    If the wiring from the sensor to the ECU is fine, check the sensor's resistance which should be 1 M Ohm or higher.
    If both of these check out OK, consider trial swapping the ECU in case of a dry joint or other fault in your existing one.
    GSE20 IS250 - daily
    AU
    Quote Originally Posted by manny
    Awesome info Manny, cheers mate.
    Thanks all for you help on this, very much appreciated.
    AU
    Hmm now that I think about it, a few months ago the starter motor was replaced.... maybe they have bumped the wire and now it has come off.
    I will have to check ...they may have been swapped around.
    is it even possible for the sensor wires to be swapped? I wouldn't have thought the wires to sensor 2 would reach sensor 1.
    QUICKEST 1JZ'S IN OZ
    AU
    Don't know, but I will be putting in a big effort to find out tonight after work
    AU
    Well tried to get to the knock sensors tonight.... basically impossible to get to without taking the inlet manifold off
    Next stop, mechanic, not playing around with engine bits... way out of my league.
    nothin' doin Grease Monkey
    pm sent...
    Quote Originally Posted by Rex_Kelway
    i am of no speech
    AU
    Quote Originally Posted by Steve-AE86
    pm sent...
    PM sent back
    and read
    i am of no speech
  1. front end knock
    Last Post: 31-12-2005, 10:00 AM
  2. 1jz knock sensor
    Last Post: 07-12-2005, 04:42 PM
