Results 1 to 9 of 9
Thread: AE86 Radiator Upgrade 4AGZE powered
    Junior Member Grease Monkey craigy's Avatar
    Default AE86 Radiator Upgrade 4AGZE powered
    Hey Guys,
    I've done a bit of a search and didnt come up with much so i thought i'd ask the question.
    So whats a good radiator that will keep my 4AGZE sprinter nice and cool?
    i'm running the standard radiator at the moment and it seems to be working ok but its only a matter of time (and change of climate) until it overheats.
    Keep in mind the car is primarily used for track/drift days
    I dont mind making custom brackets etc, just want something that has a greater cooler capacity and has both inlet and outlet on the drivers side.
    I had a triple core custom copper radiator priced at $350, i reckon i'd be able to get something just as good off a wreck for much less.
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Default Re: AE86 Radiator Upgrade 4AGZE powered
    An automatic Excel radiator is a good upgrade and basically bolts in.
    you talked to Ben about this Craig? as a drift mostly, it opens up a lot of options, i'll have a look at some catalogues if i get the chance (finding rads with both outlets on the RHS isnt that easy)
    350 sounds pretty cheap to me, a standard radiator is about 250!
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    what model auto excel is it from??? year model?
    4AGZE powered AE86
    SR5 dual cab Hilux
    You could even add an oil cooler. It helps my ke30 keep the temps down.
    Im using a wreckers spec AE71 radiator with a 14" thermo.
    i'm already using an oil cooler, i dont think the temp would stay down without it
    4AGZE powered AE86
    SR5 dual cab Hilux
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Rex achieved twin coredness with His standard radiator. Rex's factory radiator has metal tanks so the rad-gaff basically matched a 30mm core to size and fitted it to the tanks.
    Cost Him $250, bolts straight in with all factory mounts and pipework.
    Rad
    Rex Kelway Sucks - Fabrication thread
    Rex Kelway - ABN: 41 267 379 001
    Fabrication, Manifolds and CAMS spec Roll-cages in SA...
    OMGWTF Rex is back on Toymods.
    Takai thinks that this is supreme awesomeness.
    EVO's Are the Dark Side. Grease Monkey ae86trueno's Avatar
    ST162, twin core and fits snuggly,
    Ben.
  1. 4agze into an ae86
    By julietagg in forum Engine & Driveline Conversions
    Last Post: 19-02-2007, 05:05 AM
  2. Engineer approval for 4agze Ae86
    By Tom86 in forum Tech and Conversions
    Last Post: 06-06-2006, 12:37 PM
