Originally Posted by
lexsmaz
If when you crack the bleeder nipple & it doesn't release the calliper, you have a sticky / faulty calliper piston ....If it was residual pressure due to m/cyl etc, when you crack the bleeder nipple, fluid would expell through the bleeder & the disc would turn ...from your second explanation of the layout i now understand, & all sounds ok, the proportioning valve definately on your system does not control the fronts, because you only have the left hand side front runing through it, & its only there to help regulate the pressure to the rear's .. Sounds like you may have 2 dodgy front callipers, Thats the first area of address then go from there ......
