Results 1 to 6 of 6
Thread: DIFF identification
    May 2007
    Exclamation DIFF identification
    i got a centre for my soarer.
    problem is my sideshgafts dont fit it.i counted the splines and come up with 29.im guessing this is for the cressida or mx83 i beleive it is.
    can anyone help regarding how do i tell if its for gz series?
    thanks
    May 2007
    Default Re: DIFF identification
    and the crown wheel uses 10 bolts
    Picture ? MX83 has 30 splines . Soarer JZZ has 30 splines. Slightly different though. Both have 10 bolts for crownwheel.
    Jealousy is a curse
    May 2007
    I will recount the splines.but all i know is its not for the jzz30 as the shaft wont even go inside the centre.
    May 2007
    Ok i have had the centre looked at and can confirm it is from a mx83 can anyone let me know how much this would be worth? it is a cusco centre.
    thanks
    Quote Originally Posted by Muziiz
    The MX83 shafts I have are the same diameters as the JZZ30 shafts I have here although the spline profile is different. What ratio is stamped on the crownwheel and how many teeth does it have?
    Jealousy is a curse
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 12:41 PM
  3. jza80 diff mounts into the diff cradle ???
    Last Post: 08-05-2006, 12:35 AM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
