Well your axle is 45mm wider so you will need an offset of 22ishmm more positive to sit the centreline in the same place as the factory axle. Your tyre width will have more impact on your clearance than your rim width, a 235 on a 7 inch rim sits in the same place as a 235 on an 8 inch rim if they have the same offset. Work out what tyre size you want and go from there. Alot of the later model stuff is getting up to the 50's range but probably not too much of it is in 4x114.3 stud pattern.
Callum
