I'm fairly sure one of them is for boost cut/guage, and one is for the ECU.
Short answer is yes, you need them both.
Hey all,
howcome there are two sensor labled "turbo pressure" on a 1JZ and have different part numbers? what is each good for? do i need both?
'88 Soarer GT-L
'90 Supra Aerotop
hmmm. . .alrighty then
thanks
'88 Soarer GT-L
'90 Supra Aerotop
I gots me doubtsOriginally Posted by Draven
One will do the ECU (does boost cut as well).
The other one be for the gauge in the dash (If you don't have this then you don't need that sensor).
Factory MAP Sensed Nissans are like this. One for ECU, seperate one for the dash guage.Originally Posted by wilbo666
Current daily: AE92 SX Hatch
Previous rides: ST141 CSX, SA63, RT142 Avante, AE82 Twincam, AE82 GZE.
Coming Soon: Jza80 Supra... One day...
AE82 Owners Club - http://www.ae82.net
one map is for ECU (which in turn has boostcut)
the other is jsut to control the boost guage on the dash thats all.
I was saying what Xistant said.Originally Posted by Mitchee
The MAP sensor that controls boost cut is the ECU one. NOT the dash one.
Yes there is a sensor for the dash, however it doesn't have anything to do with boost cut as the gothic Draven suggested
supplying a bit more info.
the one on the firewall, above the motor, is the MAP sensor, i think the labels Green.
the one on the passenger side sus tower, label (mine is) is Yellow, is the guage sensor.
Elmo.
yeah mines the same. . . . one yellow and one green. . .
but i still have the other problem -
still blowin fuckin clouds of black smoke out the back. . . bit of a worry
all the lines to the MAP sensors seem ok. . . .must be the o2 that i cant get to coz i rounded a stupid bolt and cant get the factory plumb back valve off so i cant angle grind the bastard
'88 Soarer GT-L
'90 Supra Aerotop
