the car should normally be idling around the 900 - 1000rpm mark.
are all the vacuum lines ok?
just found this as well might help you out.
http://www.toymods.net/forums/showthread.php?t=25948
My 1987 ST162 automatic celica shakes when I stopped at the lights or at a stop sign when Im still in Drive. When I put it into neutral it clears right up, or park, but as soon as you go back to drive and still stopped it shakes again. Its a real pain in the ass.
I changed the gearbox oil but that didnt do much except make gear changes smoother.
Also when stopped in Drive the car idles at 800rpm, then when I put it into neutral or park it rises to 1400rpm, then I go back to drive it returns to 800rpm.
Any ideas?
Could this be two different problems?
"There is a better way to do it, find it" -Thomas Edison
Thats another thread I started, the ISCV I cleaned had not effect on the shaking.
Engine mounts or the engine might have a slight miss
How are your spark plug leads?
I am the sun
