The problem you're going to run into is that most race fuels have significantly higher density and much higher octane than pump fuel.
Why these two things are a problem for you is that with the same management you're going to run richer on race fuel, which isn't ideal as you're currently running mistures that will get you maximum horsepower. Plus the race fuel burns slower due to the higher octane level meaning that if you can't get some more ignition timing into it you're going to lose power due to the combustion process occuring later in the crank rotation.
Basically what I'm getting at is you want to run the lowest octane that is safe for your setup. If your current setup runs perfectly on 100 octane fuel with no pinging then bumping it up to 110 without making changes to the management will reduce power.
Personally I'd keep an eye out for a cheap aftermarket computer as I suspect you'll be able to get more gain from that than race fuel on the stock management.
