Page 1 of 5 123 ... LastLast
Results 1 to 15 of 66
Thread: [Guide] 2T, 3T-c & 18R-c Electronic Dizzy's. "How To"
    south austraila
    Default [Guide] 2T, 3T-c & 18R-c Electronic Dizzy's. "How To"
    You will need to find a RA60, RA65, RT133,or '85 RT142,( Not the '86 ) these motors will have the parts needed.. the list, what & where..
    Coil & igniter + plugs & 12inch of wire. 21/22R motor
    Dizzy internals. rotor cam, rotor plate & pick up, springs. 21/22R motor
    The 22R will have lighter counter weights, & may be used for a different mechanical advance. Best done on a Dyno.
    Metal clip to hold plug on side of dizzy. 2S motor, SA63, ST141
    noise suppresor + plug & 8inch of wire. ST141, SV11, these have a single plug ( Blue )
    also 5mm of clear PVC fish tank tube. (info & pic's still to come)
    Pic's of the parts needed, for the conversion
    RA60 dizzy parts / ST141 metal clip / SV11 noise suppresor.
    Remove the 2 screws, holding the rotor plate / pickup, & lift wire out & remove unit from dizzy, then remove the plastic cap with a small screw. ( do not damage as you will need it )
    remove screw from top of rotor cam.. remove springs, ( again do not damage ) you can now lift out the rotor cam..
    18R rotor cam, & 21R / RA60 rotor cam. removed..
    clip on the lead's
    Some 18R dizzy's need a small Mod to fit the 21R's part's
    Before & After ..
    FAQ: What are the chances of your bits and pieces fitting my bosch dizzy?
    Answer: NO. The electronic Dizzy part's will Only fit Nipon dizzy's.
    As the parts ars from a Nipon dizzy,
    Project: '82, GA61 XX
    south austraila
    Default Re: 2T, 3T-c & 18R-c Electronic Dizzy's. "How To"
    wireing diagram & how to fit your new, Electronic Dizzy.
    Ok. To do the job.
    1. Set the motor to TDC ( or as i do, 8 deg. before, as this will help later. ), To do this, use a 19mm spanner, on crankshaft bolt, in the midle of the harmonic balencer, & rotate in a clockwise direction. Check that you are on #1, by removing the dizzy cap, the rotor button should point to #1.
    2. Undo clamp bolt, use 12mm spanner, remove clamp & bolt ( Note: 2T-G & 3T dizzys, have a built in clamp )
    3. Trace back the Black wire, from the side of the old dizzy, back to the old coil. Do this by removing the tape. It will be taped in with a few other wires. This Black wire will also join, to another, Black wire, going to your taco.
    4. Remove the old dizzy. ( NOTE the rotation & position of rotor button. This will help later. )
    5. Disconnect wires from old coil. Then remove old coil.
    6. Take dizzy back to the bench, & rebuild, with the new parts.
    How to fit new Dizzy, coil, & igniter.
    1. Connect / solder, the thin Black wire, from the igniter Green plug to the Black wire going to your taco. Then tape it up.
    2. Connect / solder, the White/Black wire, from the Blue plug on the noise suppresor, to the White/Black wire, ground -ve, you found when undoing the tape, near the old dizzy. Then tape it up.
    3. Connect / solder, the thick Black/Yellow, ignition +ve, to the thick Black/Yellow wire, from the old dizzy. Then tape it up. ( Note: RA60 has Black/Red wire, from the ignition )
    4. Tape up the Black/Red wire from the old dizzy. As it's no longer used. ( It can also be disconected from the starter . NOT the Black/white wire. )
    5. Retape, all the wires up, back to the motor, & the chassis loom. ( Note: you should not tape up the new Gray, twin & shielded cable, that goes from the new, coil/ignitor, to the dizzy. this will just hang, or ( if avalible, use the two other, " Toyota " plastic clips, to hold wire safely ) from the coil/ignitor, to the clip on the side, of the dizzy. )
    6. Move the rotor button, of the new dizzy, to the resting position, of the old dizzy. ( Note: This should be, just before #1, as it will spin slightly as you slide it in. )
    7.Now holding the new dizzy, in the same position, as the old one was removed, slide the dizzy in, watching out not to damage, the "O"ring. A small amount of motor oil, on the "O"ring will help it slide in easier. ( Note: The tongue at the bottom, of the dizzy shaft, must line up with the slot, in the oil pump, for correct fitment. )
    8. Rotate the dizzy a bit, to line up the rotor button, with the #1, spark lead on the rotor cap. Refit the clamp & bolt.
    9. Connect the Green plug, from new coil/igniter, to new dizzy, & place in clip on side of the dizzy.
    16. Recheck that the rotor button, is on #1, & is at TDC or ( 8 deg. before. )
    10. START the motor. If it was set to 8 deg. motor should start first turn, of the key.
    11. Check the timing, with a timing light, & set. ( 8 deg. before, typical. )
    12. Close the bonnet, & go for a drive.
    13. Enjoy the fact, that you will never, have burnt points again.
    Default Re: [Guide] 2T, 3T-c & 18R-c Electronic Dizzy's. "How To"
    Gold...... !
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    agreed... awsome stuff there
    south austraila
    Quote Originally Posted by fade-e View Post
    Hmmmmm... sorry... but not so good yet.. there is a few things missing..
    But .. i'll be helping another do this conversion in the next week & i'll take some extra pic's & fill in the blank details...
    Mar 2008
    That would be awesome mate!
    I still haven't had a chance to sort through all the parts you sent haha
    '77 YAMAHA XT500 - Project
    The Drivers' Vault
    south austraila
    Quote Originally Posted by toyo-al View Post
    Cool...!!! you have all the parts needed...
    i'll add a few extra things/details to this thread.. on how to set them up & where to start on the rebuild.. i'm hopping for a good set of pic's....
    Not known unless ur blown Backyard Mechanic
    May 2007
    Mine don't work... Using the ra60 22r-e coil& igniter with the st141 noise thingo and a 2tg-eu dizzy... I've buggerd up somewhere I think? OOR my dizzy is crap. So tomorrow unless I can get it to work, its 22r dizzy internals or back to ghey old points..
    south austraila
    Quote Originally Posted by Radar View Post
    Hmmmmm.... RA60 has a 21R not 22R-E...
    Ok.. as your local i'll try to get help to you.. as this is a good thing & i've never had a prob'...
    PM sent..
    i'll give details on an answer once we fix this prob'
    May 2007
    Bad igniter, swapped it over for a different one.
    Then off to sprints for a Bosch GT40 coil and 12v relay.
    Now works sensational. First turn of the key.
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Quote Originally Posted by GA61XX View Post
    i have that coil pack and all those green connectors would that mean i have a electronic dizzy? i dont know bout the internals of the dizzy
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
    south austraila
    if you have those parts with the Square plugs..
    Then it's the 21R electronic dizzy parts from a RT133 corona...
    The RA60 has Round plugs..
    Jul 2009
    New South Wales
    i believe they are round... is it still electronic?
    Cheers, Alex
    south austraila
    Quote Originally Posted by RAAAH23 View Post
    Hmmmmmmm... what part of this thread are you missing...
    if your parts look ike these in this thread .. then they it's an Electronic Dizzy..
    The Square plugs are the 21R electronic dizzy parts from a RT133 corona...
    The RA60 has two x Round plugs.. one thin wire for the Taco, & a fatter Black/red strip for the IG'
    The RA65 only has one large plug with two x wires in it.. but is the same deal as the earlier electronic dizzy's..
    Apr 2009
    I was just wondering if anybody knew what the part numbers are for the dissys they can come from, i got one from the wreckers and i think it is the wrong one i just want to confirm before going back.
    Daily - 1994 JZA80 Supra
    Weekender - 1976 RA23 Celica
    Past - 1990 RN105 Hilux 4x4
  1. 2T Head and 3T Block, standard items - any problems?
    By -NiCkeL- in forum Tech and Conversions
    Last Post: 09-11-2006, 02:29 PM
  2. 2T/ 3T carby
    By suss_slide in forum Tech and Conversions
    Last Post: 25-08-2006, 11:11 PM
