Results 1 to 14 of 14
Thread: Hilux diff ratios.
    Dec 2006
    Default Hilux diff ratios.
    My latest toy is a 1986 duel cab hilux with a 5 litre holden V8 in it.As you can imagine it is rather heavy on fuel.I am considering changing the diff ratios to drop the engine revs when cruising.
    At 100 kmh the engine revs at 2600 rpm.I am told that the engine returns its best economy at 2000 rpm and under.It currently has 4.55 diff ratio in it and I am loking at putting 4.1's in it.It has a dyna gearbox in it which has a very low first gear so when in low range it is very low speed so the taller diffs should not concern me there.
    Has anyone played with these before and is the upgrade worth while.
    Wheel Rim.
    wa
    Default Re: Hilux diff ratios.
    mate i say do it i changed my diff from a 4.1 to 3.9 and you could tell the difference even with the 22r
    be wary of the late and early model hiluxes have different housings i swaped a 4.8 centre to a 3.9 and had to change the housing due to it having an offset pinion for the higher ratio not sure if 4.55 is the same
    3.9 makes good cruiser, must be quickish with those 4.5 gears?
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Dec 2006
    OK cool, seemed like it would work.I will make sure of the fit as you have mentioned.
    Dec 2006
    Jordan,
    I thought 4.1 was quicker (higher speed) than 4.55. Therefore wouldn't it drop the engine revs??
    wa
    also the lower ratios will help with the extra torque of the v8
    With an engine like that you'd want to be going taller than 4.1:1 IMO. Something like 3.7:1 out of an auto MA70 turbo would work well I think.
    Dec 2006
    MA 70 ok I shall do a ring around tomorrow.
    wa
    do a search on ebay for motive gears thats where i got mine from
    brand new crown wheel and pinion for 490 something
    and it arrived in a day and a half
    he also has lower ratios aswell like 3.5 3.25
    Ive got a 2.78 if anyone wants to swap
    TorquePilot 1st year Apprentice
    Quote Originally Posted by badboybubby
    so, what would you swap for...? are G Series *A70 gearsets compatible to hilux G Series??
    If you were insanely fetish about power, how would it be personified??
    Current Projects: 2JZ-GTE/6speed RA23 and RA28, 1UZ-FZE/6speed RA28, XR6T/6speed TC Cortina - All with Mk3/Mk4 Supra suspension
    RA23 vs 2JZ-GTE Part 2 (Now with Pics) - http://www.toymods.net/forums/showthread.php?p=126140
    Junior Member Domestic Engineer urantia's Avatar
    anyone know if the hiace 1990-98 shares the g series diffs like the hilux?
    98 3rz-fe Hilux 4x4
    97 Hiace AWD Super Custom 1kz turbo diesel (sold)
    87 MA70 w/ 1JZ-GTE Manual Conversion GT (moss growing on roof deteriorating away but open to offers)
    wa
    yes........
    ha ha thanx, still a newb with hiaces/hilux's and exactly how much they have in common.
    98 3rz-fe Hilux 4x4
  1. Toyota Manual Gearboxes and their Ratios (W, R, V, K, T, P)
    Last Post: 05-09-2012, 02:48 PM
  2. Hilux Diff question
    Last Post: 25-09-2007, 09:19 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  4. Current model Hilux diff observation.
    By MacroP in forum Tech and Conversions
    Last Post: 30-08-2006, 05:49 PM
