Results 1 to 15 of 18
Thread: 1mz and 3vz compatibility
    Forum Sponsor Conversion King
    Dec 2006
    Default 1mz and 3vz compatibility
    just wondering if anyone knows if the 1mz heads fit the 3vz block or if the rods from a 3vz will fit a 1mz crank.
    linden
    vic
    Default Re: 1mz and 3vz compatibility
    I highly doubt it. some things were simmiler but not that simmiler.
    Dave
    I'm pretty sure they're completely different motors except for the capacity.
    This is from talk of the MR2 guys in the states who do the conversions.
    I've got a US spec EPC, I'll look it up tonight, but I'm guessing the part numbers will be different.
    Is this why Mos rang me this morning asking about the VVti 1MZ I saw at a wrecker?
    Junior Member Backyard Mechanic Jaemus's Avatar
    afaik, they're totally different. the only thing in common between 3VZ and 1MZ is the intake manifold to upper intake chamber port shape... thus you can use the TRD S/C on either motor.
    1992 MR2 GT turbo
    2009 Lexus IS-F
    Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
    Dec 2006
    maybe
    hmmm mzz10 sounds like fun and it shorter than the 3s.
    whats ppls opinions on MZvsVZ as far as weight, std head flow, strength is concerned.
    it will have a gt3582r on it so power output would be roughly the same im just wondering is it worth using the vvtiMZ series over the VZ as far as cost is concerned.
    mz series requires rods+pistons where the vz series only needs pistons to get the 600+hp i want.
    linden
    As you've said, the VZ needs a lot less work to get some decent numbers out of. Iron is good for something.
    I think the VVti 1MZ & standard VVti have similar power output, just the midrange is probably different.
    For the MZ, I've also heard that it may need liners over about 400rwhp to keep the block intact. There's a guy in the States running a TRD Supercharger & Naaas on the 1MZ installed in his SW20 with about 600rwhp, but its had liners installed after blowing the sides out of a few.
    Here you go dude ebay to the rescue. Stop playing around with the little stuff, the 5VZ is only a litttle bit heavier than the 3VZ and is already setup for rear wheel drive. Throw a decent intake manifold and a set of cams and valve springs at it and you'll be making bulk torque from no revs to 7000-7500rpm.
    Dec 2006
    mmm anyone know the weight of the vz series cause ive got a funny feeling it would be heavy as. not really ideal for what im doing.
    the mz series are between 150-170kg but think the vz would add 50kg on that easy.
    linden
    Quote Originally Posted by ToysRMe from the MR2oc
    1mz-fe's are 340-345lbs
    3mz-fe's are 346lbs
    2gr-fe's are 359lbs
    All remaining GR block v6's are 390-399lbs
    3vz-fe's are 420lbs 'ish
    5vz-fe's are 420lbs 'ish
    3s-gte's are 475lbs
    Best I can find for you. Either way it's apparently much lighter than a 3SGTE, but I assume that is with accessories and a CT26 is a fairly heavy accessory.
    Contact Gianttomato. He had a VZ or 2 around as he was organising to make bellhousings to suit them to bolt into a RWD Corona.
    Dunno bout the 5VZ. Problem is that because it's out of a 4wd, it automatically gets a price premium
    Dec 2006
    thanx josh
    mos weighed the gen3 3s long i have and it was 130kgs (266lbs) so id say 170-180kg total.
    i doubt the sixes would be lighter but as stated its probably with all accesories so may be true.
    gives me a good starting point anyway.
    the vz looks like a good thing but id like to find out about how strong the liners in the mz series are as the lighter this thing is the more i will enjoy it and the easier it will be to setup.
    linden
    thanx steve ill see what hes got.
    Gianttomato's conversion was xMZ to W50 bellhousing
    edit: this is wrong - it's VZ - my bad.
    GT's original thread
    Are you sure? I thought is was VZ.
    Dec 2006
    justfound out the rods from the later gr sreies will fit the mz series (thanx josh) and are a bit beefier in the middle which would make them a good cheap upgrade but not sure on how much stronger they really are.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    MZ's already have stuff like 6 bolts mains and are light (I can pick up and throw a block). I don't have any idea how they respond to boost etc though.
