Results 1 to 4 of 4
Thread: 1jz with no a/c or PS
    Default 1jz with no a/c or PS
    Just found these old pics of how my engine is setup. Relocated alternator to other side and sliding brackets used. No tensioner pulley in the centre.
    P.S yes I know it was dirty
    QUICKEST 1JZ'S IN OZ
    User Conversion King
    NWA
    Default Re: 1jz with no a/c or PS
    in the second pic, is the front of the alt supported? or is it only bolted to the rear. id be worried that the single mount would crack off.
    whats the belt off also?
    hello
    Xistant
    Guest
    belt would be sized up with a piece of string then walk into bursons etc and match a belt on the slider they have, that how i got my belt when i removed A/C
    That bolt goes from the front of alternator to the mounting bracket as you can see. Underneath is the "slide" bracket which is used to tension it up.
    Hasn't cracked so far? Been revved pretty hard.
    xistant is correct no idea what it is off.
  1. 1JZ vs 7M alternator useful info and pics
    Last Post: 22-06-2009, 04:10 PM
  2. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  3. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 06:52 AM
  4. 1jz vs 2jz heads
