Rod would be the man to speak to about trailing arm bushes - he's gone through a few on his Ra28.
Im going to upgrade my trailing arm bushes for my RT142 corona. The trailing arms are the same as ra23/28's and they share the same part number bush according to the redranger website. I read somewhere on this forum that you can use KE70 bushes but the RT142/Ra23 metal sleeve. The sleeve is forced into the smaller hole to create a stiffer bush?? However, I though that ra23/28/rt142, ke70/ae86 would have used the same bush anyway?? Who has done this?
...... butt scratcher?!
Just did some extensive searching (the search function is so shite) and found what I was looking for. It was what I thought, what Rod used, is Ke70 bushes with Ra23 bolt sleeves. The Ke70 uses a 12mm sleeve where the ra23 uses a 14mm sleeve.
the bush is identical (super pro ones) but the crush tube is different (id only) the od of the tubes are the same.Originally Posted by Pube
linden
ps use superpro as the nolathane/noltec ones flog out too quick.![]()
