in the second pic, is the front of the alt supported? or is it only bolted to the rear. id be worried that the single mount would crack off.
whats the belt off also?
Just found these old pics of how my engine is setup. Relocated alternator to other side and sliding brackets used. No tensioner pulley in the centre.
P.S yes I know it was dirty![]()
hello
belt would be sized up with a piece of string then walk into bursons etc and match a belt on the slider they have, that how i got my belt when i removed A/C![]()
That bolt goes from the front of alternator to the mounting bracket as you can see. Underneath is the "slide" bracket which is used to tension it up.
Hasn't cracked so far? Been revved pretty hard.
xistant is correctno idea what it is off.
