Results 1 to 2 of 2
Thread: Brake Booster push rod
    Default Brake Booster push rod
    Hi guys,
    I've replace the brake master on my Sprinter. The thing is there is not enough adjustment on the stock booster push rod to match with the new master. So I ended up with a sloppy brake pedal with way too much slack.
    Anyone know if you can actually buy a longer push rod? or is there other booster that have a longer push rod that can be use?
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Default Re: Brake Booster push rod
    Hard to know what you want without knowing what you have replaced the stock unit with, but generally, yes, longer push rods are available. Perth Brake Parts in Kewdale would be able to help you.
    RA23
    1G-GZE
    By The Witzl in forum FAQ
  2. remote brake booster?
    By CHB in forum Tech and Conversions
    Last Post: 02-05-2013, 11:35 AM
  3. brake booster selection
    By STR8 2.8 in forum Tech and Conversions
    Last Post: 27-09-2006, 06:48 PM
  4. Removing brake booster, for race?
    By Jonny Rochester in forum Tech and Conversions
    Last Post: 10-01-2006, 09:26 PM
  5. 20V Brake Booster Vacuum Problems
    By ShiRi in forum Tech and Conversions
    Last Post: 15-12-2005, 07:06 PM
