Results 1 to 14 of 14
Thread: Flatplating of the oil pick-up?
    Junior Member 1st year Apprentice HRV-00S's Avatar
    Apr 2007
    Default Flatplating of the oil pick-up?
    Hi people, I'm just about to start putting back together my 4agte and have been searching around for all the little tips and tricks to make things a little easier. One thing that I came across was the term "flatplating" for the oil pick-up. I was just wondering what the process is for this as oil supply is kind of important apparently
    Thanks Dan
    4agte wagon
    aka the butterfly-cause no one suspects the butterfly
    S.A
    Default Re: Flatplating of the oil pick-up?
    cant say i have heard of this
    Apr 2007
    Yeah, I came across it in "the guide" and the guy seemed pretty adamant that it should be done, I've never heard of it either, wondering how it's done/what's involved. I don't think my motor has the locating dowel/protrusion he's talking about.
    Post #17 on the first page
    http://www.toymods.net/forums/showthread.php?t=3854
    4agte wagon
    perhaps the flatplating they are referring to is for grinding the housing of the oil pump, so that the mating faces are "true" and don't leak.
    ie, plate of glass with 1200grit or whatever, and carefully make the surface flat (although that is not as easy as it sounds )
    S.A
    hmmmmm im still not sure what you are talking about sorry ?
    Can you post a pic or a quote.
    perth
    ha is that what they meen I do that every job i get anyway, do it in figure 8's
    you get your oil pump cover remove the plate holding in the pump get a plate off glass some fine grit wet n dry, spray lube and work in in figure 8 to get a total smooth finish and the gear and so forth.
    yeh dont play with side clearance as you can do worse than good.
    Quote Originally Posted by 30psi 4agte
    get a plate of glass (i usually use an A4ish sized one).. then get wet n dry paper (fine is ok, as alloy is soft).
    have RUNNING WATER going over it.
    then get the oil pump, split it, and the mating faces, you grind down so they are parallel and will seal better. or so the theory goes.
    you can also do the gears to set the side clearances between the gear and housing, but getting stuff parallel and properly flat (not engineeringly flat ) is a real pain in da butt.
    S.A
    yeah found it in the end stu............... christ im going blind
    And like fixer said ......I do that anyway without even thinking about it but it is something for people who dont build motors all the time to lookout for !
    I wouldn't have done it, and I'm gonna rebuild my 1g...
    Facebook | LinkedIn
    Apr 2007
    Thumbs up Re: Flatplating of the oil pick-up?
    That's awesome guy's, I've built a couple of motors but only fairly standard stuff and have learnt a lot a long the way, I wish I knew about this site back then. It's nice to know that when you get stuck with something or need some inspiration there's usually someone to help
    Cheers Dan
    4agte wagon
    he's talking about the oil pick up, not the pump, u do the same as stu has said but u grab the pick up and to do it to the face that meets the pump/block/whatever, use 240 grit with CRC, used to do it all the time as they warp
    The boobs are back
    Apr 2007
    Thanks mate, I assumed that you could use the same technique for all the sealing surfaces, water and oil?
    4agte wagon
    pretty much
    The boobs are back
    Apr 2007
    Hey, I done the pump and the pick-up today. The pump wasn't that bad only took a small amount of sanding to get it flat, but the pick-up was pretty bad and took quite a bit to get it nice and flat. Well worth the little extra time and effort.
    Thanks for the help guys
    4agte wagon
