Results 1 to 8 of 8
Thread: Steering Rack Grease Type
    May 2006
    Question Steering Rack Grease Type
    Hey Guys,
    I am about to reco the steering rack in my AW11 SC but I don't know what type of grease to use. Does anyone know what type Toyota used from the factory in their non-powered late 80's racks?
    I'm thinking Moly but am unsure.
    Any thoughts?
    Matt.
    Jun 2007
    Default Re: Steering Rack Grease Type
    Call up a Toyota Service/Parts department. They'll most likely sell it in little packets enough to do 1 Steering rack.
    Unless you want to use some non-Genuine Grease ?
    Probably moly, I'm pretty sure it would use the same type of grease that is used to pack CV joints with
    I am the sun
    May 2006
    Non-Genuine grease will probably be the preferred stuff. It'll be worth twice as much from Toyota Genuine and its not under severe heat or pressure so I'm thinking a 3rd party grease will be fine - just which one?
    Dale, I'm also thinking Moly but not sure, I cant see why not though. Moly grease is OK in contact with rubber (Rack Boots) and it lubricates. That fits all the requirements I think.
    Maybe it doesn't really matter in an application like a non-powered rack. No heat & no pressure.
    Matt
    May 2006
    Anyone else?
    Jun 2007
    From the Castrol Australia Website
    Steering Boxes
    Follow manufacturer recommendations. If the steering box is grease lubricated
    use Castrol EPL0 or SL Heavy Grease.
    You can use EPL1 or EPL2 but they are a little thinner.....
    The Tubes they come in cost about $8-$10 but you get a lot of Grease for your moneys worth.
    Traditionalist Domestic Engineer parrot's Avatar
    Toyota manual states
    Molybdenum Disulphide Lithium Base grease
    I got some from my local BP servo.
    Cam mountain I feel different from the ordinary
    May 2006
    Moly it is then.
    Thanks Parrot, I have a Haynes workshop manual which conveniently doesn't state but the Toyota manual could be considered gospel.
    Thanks All,
    Matt.
  1. Can you adjust steering stops with rack & pinion?
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 22-07-2012, 01:30 AM
  2. AE86 "Cusco" quick steering racks??
    By oldcorollas in forum Tech and Conversions
    Last Post: 02-06-2007, 12:13 AM
  3. ra65 rack and pinion power steering rack
    By Intense in forum Tech and Conversions
    Last Post: 26-04-2007, 11:12 PM
  4. 162 Celica Steering Rack Help!!!!!!!!!!
    Last Post: 03-05-2006, 05:43 PM
  5. Help Needed to identify Steering Rack
    By Art Racing in forum Tech and Conversions
    Last Post: 10-03-2006, 06:32 PM
