Results 16 to 17 of 17
Thread: Ball-Bearing Myths........
    Default Re: Ball-Bearing Myths........
    something makes me doubt that porsche would put a low quality item into their flagship model I guess time will tell
    Chiba
    Quote Originally Posted by Draven
    new 911 turbo variable vane turbos ftw
    Actually the 977 Turbo, the turbo is made by BorgWarner and the technology used for the variable geometry system has been kept quite secret. "Advanced aerospace technology" as they put it.
    Quote Originally Posted by Moppitt
    The only problem is that they dont have wastegates so you cant run a screamer if your so inclined
    You can run a wastegate, they are still used if the full open position of the geometry isn't sufficient to allow boost to be controlled to the desired level. Some VGT systems will over-boost if a wastegate isn't fitted.
  1. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  2. Belt tensioner / nevo equivilent / bearing
    By TooF in forum Tech and Conversions
    Last Post: 17-05-2007, 07:37 AM
  3. mz20 (ma70) centre bearing (center bearing)
    By Bored? in forum Tech and Conversions
    Last Post: 26-04-2007, 10:29 AM
  4. Replies: 31
    Last Post: 25-04-2006, 10:00 PM
