Results 1 to 13 of 13
Thread: Ignition barrel problem
    Junior Member Backyard Mechanic celicaboy_2000's Avatar
    Default Ignition barrel problem
    I have taken my ignition barrel out of my RA23 celica but now I have a problem My problem is that I accidentally turned the key to the Lock postion and now cant turn it back to Acc to reinstal it back into the steering column. I have tried pushing/lifting the lever etc but still cant get the key to turn, somebody help me.
    Matt
    Default Re: Ignition barrel problem
    how do you normally get your key out of the barrel? do you need to push in before you turn? in ta22s you push a button and turn to get the key out. The cylinder where the key shaft slides into should come out.
    deepdishfactory
    Aug 2006
    I would say there would be some sort of button you press as w810sc has mentioned,
    Hit it with a hammer, this works for me when i get s**t stuck
    The lever you are pushing and lifting is for the steering lock on the steering column. Some how Evo 7's have a similar design.
    Have you tried pushing the lever down and turning the key?
    deepdishfactory
    I have tried everything I can think of, normaly I have to press the button on the shroud to turn from ACC to Lock BUT the key is already in the lock postion so I thought it should just turn to the ACC position but it doesn't... If all else fails of to a locksmith to get it (fixed)
    Matt
    Aug 2006
    Don't pay a lock smith $50 when you could probably get one from the wreckers for $5 with a key that works on all your doors and boot
    Thats the thing I had no problem with this barrel it works fine in the car just not out of the steering column.
    vic
    Wiggle it like you wiggle something else with some lube in it and you will get it . i did this a few years ago and i managed to get it turning again , i learnt my lesson tho so i dont turn them when there out .
    Dave
    I ended up taking the barrel & key to the locksmith and got it fixed! The problem was that the barrel was worn and keys were worn! So they replaced the tumblers in the barrel and cut me some new keys... Like NEW. Thanks for all the replies.
    Matt
    Aug 2006
    How much did this cost?
    $35, I thought about getting another barrel but the same thing could of happen in the near future so I thought it would be easier and more cost effective to get it all done.
    Matt
    Aug 2006
    $35 aint that bad.
    Yeah I was quite happy.
    Matt
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. ignition problem with dual carbs
    By sticky667 in forum Tech and Conversions
    Last Post: 08-10-2006, 07:01 PM
  3. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
