Page 1 of 4 123 ... LastLast
Results 1 to 15 of 59
Thread: still no spark for 1ggte???? UPDATED (reward offered :D)
    Default still no spark for 1ggte???? UPDATED (reward offered :D)
    hey guys tryin to get my soarer running which has a 1ggte
    and i replced the ecu and dizzy but stil getting no spark
    so bridged t1 and E on the diagnosis and code 14 came up
    so thjats ignition system
    does any1 kno wat could be wrong y im gettin no spark
    maybe crank angle sensor or sumthin
    Default Re: no spark for 1ggte????
    a lck of vowls mkes hrd to ansr
    re-check connections between igniter and ECU?
    victoria
    all the sensors are in the distributor-(3 reluctors)
    checked your coil/ignitor? ive got a spare if your interested
    haha yeh i was in a rush to type it
    but yeh i checked a few things out
    and ill check a few more things tomoz
    i'll LEND you my coil...actaully, if you want i can add it to your T A B, as i wont need it,
    lol yeh ok i mite borrow it
    il come up tomoz when i wake up
    User Conversion King
    NWA
    check a wire hasnt fallen out of the plug
    hello
    Default Re: still no spark for 1ggte???? UPDATED
    ok guys
    tried another coil and ignighter and sill nothing
    it sounds like an imobaliser but the car dont have one, cause the car goes to start but dont kick over
    wat can it be??
    Bored d00d Backyard Mechanic H1TMAN's Avatar
    Jan 2007
    get a 12 volt test light and test all your wires to see if one has a problem.
    Miss my Ma61
    yeh tru ey ill c wat i can do tomoz
    ill give sideshow a call or ill try get a wiring dude out
    check for power at the injector plugs while cranking.
    if none then id be looking around the key barrel as it tells everything to get going. and the injectors are powered from the barrell.
    Black Betty >HERE!<
    (\__/)
    So what happens, do you actually GET spark? do you actually GET fuel?
    Does the engine actually turn over? Or does it not turn over?
    Facebook | LinkedIn
    victoria
    it goes to start. nananananana but doenst kick over
    as if its an immobalisrer thing
    im gettin no spark at all
    ill even get u boys a vid of it 2day
    victoria
    so starters engaging and turning the motor over, but it just doesnt catch.
    youve got fuel out of your return line, and signal to injectors?
  1. Error code - "Load signal circuit" help needed (4Y-E)
    Last Post: 10-02-2008, 03:23 AM
  2. Trouble matching paint Code. 1973 RT104
    Last Post: 16-08-2006, 02:55 PM
  3. engine diagnostics code????????
    By pinkky in forum Tech and Conversions
    Last Post: 12-06-2006, 01:47 PM
  4. Factory Code for 98' Starlet Radio
    By rollin_stock in forum Tech and Conversions
    Last Post: 07-06-2006, 04:56 PM
  5. 1995 Celica radio code
    By splatt in forum Tech and Conversions
    Last Post: 16-05-2006, 08:57 PM
