Results 1 to 8 of 8
Thread: How to remove car door lock - lost keys.
    Negative Reputation Domestic Engineer Howieau's Avatar
    Default How to remove car door lock - lost keys.
    Hey lost my car keys. I have contacts to a locksmith and am told that if I remove the car door lock there should be a code on it that he can look up in a database and make a new key from.
    So how do I remove the lock? I understand how to remove the door trim and such, but is there any tricks I might need to know in pulling the lock out?
    The car is a ST162 Celica.
    Many thanks.
    "There is a better way to do it, find it" -Thomas Edison
    Default Re: How to remove car door lock - lost keys.
    Pull the door trim off and unclip the nylon clip which holds the locking rod in place and remove it from the lock, then use a 10mm socket or spanner to undo the bolt retaining the lock into the door handle
    It's optional to pull the whole handle out, certainly not necessary just to get the locks out though.. I've done it with them in before and it's a lot quicker and easier than taking the handles out to do it.
    I am the sun
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    The lock code is usually on the passenger side lock by the way.
    Another option is to try a few other toyota keys - most old toyotas can be opened/started by glaring at them, let alone anything resembling a key.
    locksmiths can supply new barrels set for a specific key (for doors) if they know what their doing - my RA40 had the mismatching barrels replaced when it was being repainted.
    Otherwise remove barrel from a door or the steering column, take to a locksmith and get them to make new key(s) to suit.
    Or buy a new ign barrell and door lock set from a wrecker.
    The hardest bit with removving the doorlocks is if you aren;t confident with those nylon clips. Flat blade screwdriver prises them off.
    Ign barrell should come out with key to ACC and press that little button up the back of it and pull.
    Quote Originally Posted by Starfire
    Turns out the key code was on the drivers side lock and the locksmith said 9 out of 10 times it will be on the driver side, for anyone who may read this looking for info on getting their code.
    I opened my old celica with a five cent piece when I locked my keys in it once
    I got my locks recut the next day
    Apr 2007
    queensland
    i could open my ra23 with a screw driver, CAUSE SOME ONE BUSTED THE LOCKS WHEN THEY TRYED TO STEAL MY SOUND SYSTEM, next day i got a alarm and a set of solex locks.
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 05:11 PM
  2. How to remove doorlocks on an AE9x
    By The Last Streetfighter in forum Tech and Conversions
    Last Post: 17-03-2006, 03:29 PM
