My engine is bog stock ZE with a turbo, has been in the car for 6.5 years and has run 19psi for the past 3.5 years.  No problems at all, it's my only car too so it goes everywhere
   It also sees the track, drags, motorkhanas and general good times
Please keep the tech section to facts and peoples personal experience not hearsay and rumour
My brother ran his 4AGTE (OEM pistons, bottom end etc) on ~24psi with no problems for a short while.  He did need to upgrade the valve springs (due to the level of boost causing valve float) and he was running 550cc injectors.  I have run mine at 21psi but it's beyond the efficiency of the turbo and peak power is not much higher than at 18-19psi so it's not worth running any higher on my car.
An experienced tuner should be able to find the maximum boost/timing/rpm your engine will safely handle.  Probably better to let them determine the limits and see what power you make with it rather than having some people on here hit you with numbers that may not be suitable for your particular engine setup.  Detonation and excessive rpm are the main killers of an engine that is going to get hard time.
What sort of driving do you plan to do with your car mate?
